Hi all, my 97 stagea has a leak!
Ive got Water getting in through the back somewhere?
It's not from around the door/hatch but I've noticed it leaking from under the corner plastic trims, (near the tail lights, between the quater window and door opening) then leaking down the carpeted trims and filling my cargo mat.
Both sides seem to do it, depending on where it's parked, and Wich way the rain is blowing.
Has anyone had this? Would it be from the cover on the body vents? Or from behind the corner tail lights/indicators? Or possibly the windows.
Any advice on this before I start pulling it apart to investigate would be sweet.
Cheers, Nick.
https://www.sau.com.au/forums/topic/420887-water-leak-in-rear/
My M35 stag had the same problem.
Showed it self on a rainy day.
Do you have 3 child seat restraints fitted in the roof at the rear?
In the M35 they drill through the water Chanel to install them! Forehead slap!
Which would have been "ok" except the water doesn't stop flowing down the Chanel just because the safely anchors are installed .
I had to pull them out and seal under the mount plate with silicone.
All fixed, was just lazy workmanship .
Make sure you just put silicone under the plate and around the hole, and NOT between the plate edges and the channel edge.
Water still needs to flow down the water channel if required.
I do have 3 anchor points but they are in the middle of the roof between the seats and door, is this the area your talking about?
I did find a thread about that but they all mention as though they have been mounted right on the door Chanel and the bolts go through to the hinge mounting area.
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
