S A U - N S W Tech Night For Members 24Th Apr - Engine Builds
AUTUMN TECH NIGHT by SAU.NSW
In conjunction with JUST ENGINE MANAGEMENT
Many Thanks to Bobby and Adam for helping SAU to set up this big night out!
Day/Date:- Wednesday 24th April
Time:- 6.30pm till about 9-ish
Place:- JEM Mechanical 2/2 Noonan Rd, Ingleburn SEE LINK: https://maps.google.com.au/maps?q=2%2F2+Noonan+Rd,+Ingleburn,+NSW,+2565&hl=en&sll=-33.993864,150.860224&sspn=0.019107,0.042272&geocode=CQrhvPLabsQxFU9h-f0d2fv9CCmzKtSVYesSazEYsuq0qxcPBw&oq=2%2F2+Noonan+Rd,+Ingleburn+NSW+2565&t=h&hnear=2%2F2+Noonan+Rd,+Ingleburn+New+South+Wales+2565&z=16
Limited To:- Members Only x30 and Execs x6 = 36 all up.
Price:- Free Of Charge. Try to feed your tummy before coming.
The Night:-
* Free Tour of the establishment
* Views of 2 very special R34 GT-Rs on hoists 1) by JEM and 2) by SAU.NSW
* Lecture and Visual Display of Engines Builds
* Question Time - so bring your Qs
So If You're a Member, Register Now!
And keep viewing this thread, because a confirmation will be required closer to 24/4/13
1) God_speed (M)
2) DekA (M)
3) vorse (M)
4) crashdown (M)
5) PN-Mad (M)
6) Duncan (LM)
7) BakemonoRicer (M)
8) levinboy (M)
9) r32-25t (M)
10) 533 RYC (M)
11) Victory (M)
12) Clinton (M)
13) CLNSKY (M)
14) PRO_32 (M)
15) skylinekido (M)
16) Watchamacallit (M)
17) DC33VN (M)
18) Spring&WateR (M - subject to approval)
19) xntrq (M)
20) Mitch_Rona (M)
21) intune (M)
22) 34GeeTeeTee (M)
23) FeZ25 (M)
24) darksky34 (M)
25) JimmyRikard (M)
26) nick_7g (M)
27) twotwisted (M)
28) megzz (M)
29) Calsonic 14U (M)
30) ianjb (M)
Execs
1) Pezhead (P)
2) Terry_GT-R34 (E)
3) GoldZilla (VP)
4) luke GTR (E)
5) Aggroman (E)
Reserve List of Members
1)
2)
Non-Members need to join up straight away please, if interested.
  • Replies 195
The blue 34GTR they have there at the moment is a real piece of work. Some clever engineering has gone into the turbo setup and even from lowish boost levels the results are very promising.
Too bad I can't make it due to work :(
:action-smiley-069: Anyone who is not a Member yet and wishes to come, please download the Membership Application sheets > fill in > sign Code of Ethics as well as application > email the form and your bank details to our Secretary "Shell" straight away!
(Fax is redundant & slow mail will be too slow methinks)
Sign me up!!! Not ever been to a tech night. Not sure if membership current can someone check???
"Shell" will be able to tell you.
She's sent out a new batch of renewals too - so it's a good opportunity for everyone to get cracking!
Post #1 is up-to-date :)
In just 10 hours, we're half full now.
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
