hey just having a problem with my temp gauge on my r32 when i start the car it goes all the way up and stays there i hooked a aftermarket gauge up and it seems to do the same anyone know what the problem could be or if its just the temp sensor
thanks.
Edited by nismo091
https://www.sau.com.au/forums/topic/420912-temp-gauge-problems/
thanks.
May be your thermostat mate get it checked out to make sure it is functioning well etc
Nip into natrad
But seriously does it go Immediately to hot when you start the car (within a few seconds?) ? If so electrical gremlin
If it takes a bit longer like normal warming up from cold and goes hot after a few minutes - then dont drive it. Get it checked out or the consequences will be serious,, if not already.
Youv'e checked the basics ?
Ie: is full of coolant, flushed it properly, refilled, no air in the system, waterpump working? Therrnostat as above
the cooling system seems to be working fine had the car running for a while it has brand new water pump when i turn the key to on position the temp gauge goes straight to hot but when i turn the engine on it goes straight down and does not move at all the heater works so that tells me that the thermostat is opening up the rpm gauge does not move at all either i dont know if it has anything to do with that or not i know the engine has been changed it is a r32 gtst with a rb20de put in it and previous owner has done the conversion could there be anything he forgot to plug in or anything like that
Think your right. If your RPM and Temp gage are playing up then yeah.
Good luck sorting it. -> Auto electrician time
Edit: Can you swap cluster over with a known working one just to confirm it is wiring and not cluster. (5or6 screws)
  • 2 months later...
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
