just did this for 95kg (rounded up from my present body weight of 93.6kg)
Got 17 reps out, which I was rather pleasantly shocked by. Pretty sure I have a few more there but, I am expecting to have lots of soreness from being very rusty. 20 might be in reach after all.
The missus home gym bench is pretty crap, it felt like it was going to give in/break . Very wobbly (you can see in the vid) and it's fairly high off the deck. It must only be rated to 100kg or something. There won't be any 1rm attempts on this one.
http://www.youtube.com/watch?v=Y3NT8-3xlHM
Edited by rev210
  • Replies 214
Just typical ,only a few hours after doing this and I am fricken sore, safe to say this was too much too soon doh!
lol you always push yourself over the top. How did your shoulders hold up, any injuries? May get you back into bench...
Nah , rounded up is fine. I don't think it will matter too much. I'd rather drop body weight to 90kg and be done with it ha ha...
shoulders are solid. I have put work into them and my back. Not enough for me to go chasing 1rm just yet but, enough for this. I did some 105kg strict presses a few weeks back so benching below that weight should be alright.
You should throw up some before and after pics of weight loss in your thread (preferably Skyline window reflection). It's quite an achievement at your age (and gives me hope for the future lol).
Leigh and I did this fresh tonight...never again! It f**ked us good for the rest of our sets :( Couldn't even get my 1RM out tonight. Vids will be up tonight or tomorrow morning.
I really wanna try this, but im 3kg off benching my body weight :(
You can do the girls' one if you like, at half your bodyweight :P
Keep at it dude, honestly I think bench pressing your own bodyweight is a benchmark for anyone...I know I was pretty happy when I was able to do it.
Leigh
BW: 73kg
BP: 72.5kg x 12 reps
Leigh's form was a tad average, not touching the chest on a couple of reps...but for a first attempt and no back arch, I'm pretty happy. He's only been training with me for 4-5 months and has come a long way IMO, already putting up a 1RM of 90kg. Well done mate.
http://www.youtube.com/watch?v=p1lqKDXp_aA
Charlie
BW: 66.5kg
BP: 32.5kg x 10 reps
50% of bodyweight, as per female rule. Congrats dude, this was good form.
http://www.youtube.com/watch?v=bBeRSBxPUto
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
