Thanks Birds and thanks for posting. tried for the 19th rep but just couldn't push it out. Bit embarrassing but hey! I was happy thinking I beat rev's 17 and then he goes and does the 22 the SOB lol :)
I'm down to 79kg now (from 86kg over 6 months ago).
Trozzle - just post up mate. It's not about winning or losing, it's about giving it a crack and improving your own performance.
  • Replies 214
cbf recording it unless I know I'm in contention for the win :P I'm happy enough with 9 reps of bodyweight though, so I'm not entirely disappointed. Hopefully I can get it up to video-worthy level before end of month :D
No one is going to beat rev at this, should still chuck up a vid though. People might be able to spot issues with form that you don't realise and it encourages others to have a go too.
Don't worry Troy I did it and I sucked
11 is actually very good. remember this is a starting point too so you can only become more awesome at it !
Challenge yourself first and foremost. It's the best mindset :thumbsup:
Push yourself, then your body will do what it's designed to do and get stronger. By the time this challenge is done I believe you can get to 22 L33SH , go for it!
Edited by rev210
I don't have your belief Rev, but thanks :)
No problem . Want to encourage your belief in yourself, I'd love to help see you go from disapointment in 11 to determination for 22.
If you 'want' 22 , 20 ,15 or even 40 enough to try for it ,then you will have the most important ingredient that will get you there. :thumbsup:
Edited by rev210
I need strength though
Thats the easy part, if there is one thing from just giving this a shot it is you will get stronger. The hard part is activating the higher performance you have waiting with mind attitude.
Think about this .... If you never give your body a shot at getting to 22 you can't actually know you will never get there. Your limits could be even higher? No one can tell you it's not possible.
You can do it!
Edited by rev210
I've tried, she gives up too easily! Can't wait til she is in Melbourne again, then I can show her what the body is capable of when you have the above :)
But I'm glad she attempted the challenge, that's half way there.
On the mind/attitude side of things, IMO the bench press tests willpower more than any other exercise. So many times (usually during 1RM attempts or low rep sets) I've had the bar half way up and - like an epic arm wrestle - have taken a solid 15-20 seconds to finish the rep, inching the bar up millimetre by millimetre, fighting back the growing urge to just let it fall. It's an amazing feeling of accomplishment and no other exercise brings that out in me.
Think I built that willpower from the days where I trained solo and, many times it was a case of get the bar up or get crushed!
It appears you do not drive with your legs at all, is that the case?
I cant say that I know exactly what that means or that I do or don't do it but I try to 'plant' my legs, get a good strong base and then drive with my whole body.
Open to suggestions to improve the technique :) .
Solid effort!
Thanks Nick. Don't think I can do many more than that but will give it another crack.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
