Hi I'm in the middle of a turbo upgrade, wondering if ican get some opinions on how much hp and on how much boost I can run out of my rb25det.
Mods are as follows
Greddy front mount
Splitfire packs
Bosch id1000injectors
044 fuel pump
Greddy hi flow fuel rail
Greddy copy plenum
Tial 44mm wastegate
Gt3582r garrett .82 rear
3in exhaust
6 boost manifold
Don't want to know about the lag monstor it will be just hp and what boost I should be looking at running on sock internals,
Thanks Ryan
https://www.sau.com.au/forums/topic/420942-power-output/
I'd say you would be safe to go for 20 pound and achieve 350 - 400 atw.
Somewhere in that region.
Much more then that will open ya self up to the rods possibly giving out.
Have seen some run more then that but no for too long with stock rods.
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6777325
Yea I know what ya mean man.
There is a lot of people that do manage to push 450...
But just keep in mind it's a gamble no telling how long it will last.
Mine is a full forged engineered motor and I push just over 400kw all day long without breaking a sweat.
But yea cause of the work I know it will keep going.
In my opinion shoot for 400 then reassess with your tuner
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6777640
Will prob be determined on the Dyno but usually 20 pound is the bench mark could be slightly above sometimes.
I wish you luck bro!!!
Do keep us updated on what you achieve.
What is your car set up for ?? I.e drift , strip?
Seeming that you haven't got a built motor you will prob have to go above 20 pound though. I've seen people pushing 23-25 pound again bear in mind more psi more stress on everything
Edited by Cyifly
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6781547
  • 1 month later...
i think its better to be more conservative as ur engine internals are still stock. the harder u push it, the more u shorten the lifespan of the engine.
my personal opinion is...why not do up ur engine first (conrods, head studs, valve springs etc) and while u're at it... change the oil seals etc too. Once u've made ur engine relatively bulletproof, u can push it however hard u want and still have peace of mind. :)
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6817599
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
