Hi I'm in the middle of a turbo upgrade, wondering if ican get some opinions on how much hp and on how much boost I can run out of my rb25det.
Mods are as follows
Greddy front mount
Splitfire packs
Bosch id1000injectors
044 fuel pump
Greddy hi flow fuel rail
Greddy copy plenum
Tial 44mm wastegate
Gt3582r garrett .82 rear
3in exhaust
6 boost manifold
Don't want to know about the lag monstor it will be just hp and what boost I should be looking at running on sock internals,
Thanks Ryan
https://www.sau.com.au/forums/topic/420942-power-output/
I'd say you would be safe to go for 20 pound and achieve 350 - 400 atw.
Somewhere in that region.
Much more then that will open ya self up to the rods possibly giving out.
Have seen some run more then that but no for too long with stock rods.
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6777325
Yea I know what ya mean man.
There is a lot of people that do manage to push 450...
But just keep in mind it's a gamble no telling how long it will last.
Mine is a full forged engineered motor and I push just over 400kw all day long without breaking a sweat.
But yea cause of the work I know it will keep going.
In my opinion shoot for 400 then reassess with your tuner
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6777640
Will prob be determined on the Dyno but usually 20 pound is the bench mark could be slightly above sometimes.
I wish you luck bro!!!
Do keep us updated on what you achieve.
What is your car set up for ?? I.e drift , strip?
Seeming that you haven't got a built motor you will prob have to go above 20 pound though. I've seen people pushing 23-25 pound again bear in mind more psi more stress on everything
Edited by Cyifly
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6781547
  • 1 month later...
i think its better to be more conservative as ur engine internals are still stock. the harder u push it, the more u shorten the lifespan of the engine.
my personal opinion is...why not do up ur engine first (conrods, head studs, valve springs etc) and while u're at it... change the oil seals etc too. Once u've made ur engine relatively bulletproof, u can push it however hard u want and still have peace of mind. :)
https://www.sau.com.au/forums/topic/420942-power-output/#findComment-6817599
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
