What i've found is the cleanest engine bays have re-painted engine covers and an actual clean engine bay itself. Usually scrubbed and repainted when the engine is out of the car.
Best basic things to do would be to look at just re-doing any old vacuum lines and clamps that are worn. Give everything within reason a degrease and a clean. Maybe relocate your battery and throw a decent oil cooler/relocation setup and an oil catch can.
If you're willing to go for it, do the rocker and cam cover. The R32 RB26 covers tend to be quite ratty these days (mine certainly are) and are often missing chips of paint. I think the R34 GTR RB26 covers are a sharp colour.
Engine out, respray the engine bay, replace all rubbers and hoses, new bolts and washers with shiny ones, get plenum and cam/timing cover powdercoated, any metal components media blasted or re-plated.
A decent job can be done for under $1000.
That's not a bad price really is there any vids etc how to pull an rb26 out?
Not sure about any vids, but i'd recommend downloading a copy of the R32 GT-R workshop manaul. Given it was sold locally, there's a full english copy available (about 500 pages in a PDF) online. Handy resource to have and will tell you were every bolt/nut/screw it located on your car.
If you havent done it before then only attempt pulling an engine out if you are pretty handy on the tools and have a good system or memory lol
Even with the engine in you can do a lot, do what dave said in terms of hoses etc, maybe get some nice shiny bits and hard pipe kits etc?
Keep it legal though, you dont want to spend all that time getting it right and then get slapped with a defect!
can you get the plenum out with out taking the engine out haven't had the best chance to give it a look
Ok,
I would pay attention to the engine covers. Why? Because when you open a bonnet whats the first thing you look at??? Yep, the engine.
Old and worn out oem paint on an R32 GTR looks like sh!t.
I know that you mentioned money is not an issue but in fact its always an issue, some are just better at managing it than others that's all ;)
That aside, here is what I think you could do.
Go to the Autobarn and get some paint stripper - $50 for 4 litres (get your money worth that way)
also purchase some VHT wrinkle plus black / red (red if the car is white) - cost approx $15-$22 depending where you get it (Autobarn is the cheapest) get two cans
Get some all-purpose primer - cost like $13 bucks from Bunnings
Remove your plug and engine cam covers and paint strip them
Clean them up with some degreaser or prep wash and sand where appropriate (if required, I didn't)
Tape up the necessary parts i.e. breather holes, screw holes, engine ornament, etc...(this is the longest bit)
Then on nice hot sunny day - use your VHT wrinkle plus spray can - make sure you follow instructions (must be sprayed in a cross patch pattern i.e. horizontal, vertical and then sideways)
More importantly - buy or borrow a heat gun - set it to 300 deg C immediately after spray painting - once at temperature, apply it to the plug cover and cam covers
It will wrinkle up very quickly and once finished, leave it to dry somewhere dry i.e. in the sunlight for a few days
so going from the boring and grubby engine bay
to
this....
besides your time - total approximate cost is $120 (if you don't buy a heat gun)
your choice mate :miner:
I got the top ornament plate powder coated and sand blasted already as I used to work at one cost me $10 for that part I just need to get the rest of the covers off without f**king the timing or anything else lol
Yep, be careful when taking the front cam cover off. I did that once and despite my efforts with markings I still managed to stuff up the timing + screw up the CAS. I think if you take it off you will need a timing light to reset it correctly.
Edited by Ants
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
