Hah Matty she is all good now. Just needed to cool down
I guess spending half the pass at 5-7k made her get a little warm :P
Good fun and all below the speed limit cause damn that was slippery
  • Replies 62
Posted Images
Had drama's with the camera. Something happened to the card & it has a bunch of corrupted files... so lost a bunch of photos.
Tried recover them, got some... Then, Photoshop wants a serial number so I had to grab a something free to resize them.
Free software goes "we can make your photos look more awesome!" so I said yes... Turns out over saturation is what people think is awesome.
These are the only photo's i managed to recover.
looked like you were having a lot of fun from where I was sitting :)
Can the couple who were enquiring about a V-Spec II yesterday please email me on
[email protected] ???
Meanwhile, I'm very much enjoying the pics.
The BMW respectably followed a GT-R all the way up the mountainside > no slipping either
Thanks mate. I believe they are around 380mm at the front. Discs are AP, and yep calipers are Brembo GT 8 piston front 4 rear. Can't sing the praises of good brakes enough, especially on a day like today!
Are the front rotors 36mm thick? Can the calipers support that wide of a disc? If you dont mind me asking, where did you source them?
I only ask as i am upgrading my brake very shortly and am weighing up my options.
If you are looking to pick up a bargain upgrade I've got a big Alcon brake kit for sale Damo? :thumbsup:
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
