Not the best with the electrical side of things but sounds like you should get a new relay and try that they're only $15-$20 for a 30amp horn relay. It should be normally open which means no circuit until the switching wire(from the ECU) triggers it to form the circuit. hook it up the way it's been explained and that'll tell you whether thats the problem. It's now a process of elimintaion so write a list of things to check and cross each one off when you've checked it.
this is what I did in my skyline
scrap all the standard fuel pump wiring and start from scratch go to jaycar (car electronics place) get a 5 pin horn relay, 30amp in line fuse, 25amp positive and negative wire(black and red I only needed a meter of each my battery is in the boot you'll need maybe 5or6 red cable and a meter black) and just tools for the job solder and iron ect
run a wire (25amp red) from the battery (positive) and put the inline 30amp fuse along the way somewhere then conect this wire to pin 30
pin 85 earth out to the body(or negitive on the battery)
pin 86 conect to an ignition only source (key barell, head deck ect)
pin 87 straight to fuel pump positive connection
negitive connection on pump you can ground it out to same place as the relay
this is basically the setup I'm running with a walbro and 2 044 they switch and run beautiful hope this helps
Ok cheers for the info, sounds like this is the way to go. Fingers crossed it solves my problem... cars huh :P
and when you get the relay ask for a wiring harness for it makes it a lot easier it cost me about $50 all up including a new soldering iron. car are a love and hate relationship
yeah thats what im thinking...just hardwire it from scratch...
Correct me if im wrong BUT doesnt blue smoke generally indicate the engine burning excessive oil or oil entering your exhaust e.g blown turbo
Correct.. being second hand I have no idea what condition the turbo/engine is in.. is on the cards to inspect inside
Edited by GTS 221
that's the love of cars mate you need to research look up stuff on google go to the local mechanic shop ask questions. I'm a bricklayer by trade and now try to go everything on my cars even tort myself to aliminium weld to get stuff done. my advise try it yourself if you stuff up you will learn by your mistakes
A quick check of the Commo wiring diagram shows its fuel pump relay is a positive trigger from the ecu, Skyline (pin 18) is negative.
Multi meter will soon sort out the problem and another relay.
Commo also has the oil pressure switch fuel pump safety cut out, so that circuitry should also be investigated.
If you want a legal and safe conversion, you never run a fuel pump without some sort of safety cut out.
85 connect to ign 12v switched
86 connect to pin 18 on the ECU header or ECU fuel pump output
30 is a fused power supply from the battery
87 is wired to the positive side of the pump
This is the correct safe way of doing it.
Edited by RRob
Are you from Melbourne/did you buy the original RB/VP from a guy from Sydney? If so the car belonged to someone I knew, and wasn't treated very best. Ran on 5 cylinders a lot (bad AFM), never serviced, etc. After the car was written off, he did a few burnouts on the lawn (cold motor). Not trying to upset anyone, but yeah. Worth putting new rings and bearings in at least.
And for the haters - fantastic sleeper. Boring white VP commodore combined with ZUTUTU. I wouldn't do it myself, but it sorta opened my eyes...
  • 1 year later...
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
