Hi Mate
i have 2 cars now for a while. a auto r32 gts4 and a old rusted out but modified r32 GTR. the gtr is very rusted so i scraped it for parts. i took the motor out for a s14 silvia swap. But looking closely i noticed a lot of similarities with my gts4 auto and gtr drive train set up. today as we speak i have the GTR gear box installed in my gts4 it fits like it was meant to be there.lol all the drive shafts lined up like the original ones do. i just had to cut the floor open for the gear sick to fit. in the morning i will move the peddles brake and clutch from the gtr to install them in the gts4. the slave and clutch master of course and see how it goes.
Seeing that the front and rear diffs are stock gts4 will i need to use the gtr's??? or will this be ok.
also can someone help me with the attessa system how do i bleed it up??? the reservoir is empty.
thank mate
There's a reason it all looks the same and fits. They're basically the same chassis. Only the panels are really different.
Keep the GTS4 diffs. People with GTRs actually want them to transplant into their cars because the ratios are shorter.
I can't help you with the bleed procedure, but I'm dead sure that it has been written up. Use google to search this site (and other sites obviously). If you use the tag
site:performanceforums.com in a google search along with the terms you are looking for you will only get results from that site. Works better than most forum search engines.
I've also posted the procedure before and am too lazy to find it again....but basically put the car in the air, out of gear, turn engine on, open the bleeder at the rear of the gearbox until the fluid runs without bubbles. Pretty easy. If you still get a 4wd light there is another bleeder above the rear driveshaft that you might also have to bleed.
thanks so much mate i will look for the links you mentioned. its funny cause i couldn't even sleep well knowing that it can work. lol
why do people look to run gts4 diffs that's funny. Do you mean that it makes for better et's in the quarter mile. (short gears)?????
well my friend you seem to be right cause all the dash look the same.lol my gts4 has a auto light built in the cluster do you think the gtr cluster will work as well.???? looking even closer it looks like if i change the truck lid and bumper the gtr rear lights would fit as well. i find this so funny.
its to bad i cant find a power fc for this rb2odet motor. i have made ok power years ago using a afc with hot wiring a z32 AFM with steel wheel tubro on a rb25det motor excluding other small mods. i cant wait to launch this car and feel the difference from auto to stick. lol.
I'm sure it will be nothing like my r33 GTR that smokes all 4's lol.
thank you for your time and consideration.
I'm not sure exactly what you mean about the instrument cluster.....they are basically the same across all the R32s. The GTSt didn't have a torque meter in the cluster, but the GTR cars did. I can't remember whether the GTS4 followed the GTR or the GTSt in that regard....I suspect they follow the GTSt....but it doesn't really matter. The tacho and speedo are all the same stuff. Same with the other gauges. The auto trans indicator is a separate thing. When I did a manual conversion into my R32 I just changed the cluster surround to a manual one to get rid of it.
Also not sure what you mean by the bootlid, bumper and lights. Is your GTS4 a 4 door? Because the coupes were all the same stuff up the back regardless of whether they were GTSt, GTS4 or GTR.
As to the question of engine management. Don't waste your time looking for a PowerFC. Visit nistune.com and buy a board for your factory ECU. Get it installed (Matt from Nistune here in Australia should be able to point you to a dealer/installer in the US) and you're away with fully programmable management in the original ECU.
interesting stuff guys. well i can conform that the the cluster is different, and that the auto indicator is in a different location. that was my bad guy's i just forgot where it was. well today i finished it up by installing the peddles and all. i noticed that the gtr has a clutch master booster and the fire wall was different with an indentation to accommodate it, but the gts4 didn't, so i ended up using a r33 gtst clutch master cylinder to get it all working. i understand now about the shorter ratios, and thanks niZmo_Man.
the gtr cluster is different. well i mean i can see it working but i would need to move around some wires cause when i put on the signal lights to the left direction the hicas light flashes, and the rpm's don't work on the gtr cluster. the physical dimensions fit. now all thats left is the transmission transfer case oil filling, and the attessa filling and bleeding procedure. oh and about the trunk lid. i was say that just the shape looks to be different on my 4 door gts4. but i'm thinking if i use the gtr rear bumper and trunk lid the lights would fit cause the only difference seems to be the inner parts of the tail lights are round, and the gtr's trunk lid and bumper looks like to would accommodate this difference. i thinking that the front bumper from the gtr could work to. i will look into the nisstune as I've always wondered about it. can anyone link me to a very good dealer in the us.?????? thanks again mate.
GTR front bumper goes on to the other Skylines easily enough. Google up someone's story. I'm sure some kid has documented it. It's not difficult.
There are plenty of 4 doors out there with 2 door style taillights too. So that can't be impossible.
Contact Nistune here in Oz direct. Matt will tell you who to talk to in the US.
its done. after driving the car. i noticed that the 4wd light comes on. any ideas. i bleed-ed the atessa system right and getting no air out now. i noticed that one of the front tires are different. its the same tire size but different height. one is 91h and the other is 89v.
One time i drove the car for a while and i noticed it stayed off and only came back in after i stopped and cut the key off to have a conversion with a friend. well i really think it's the tires. let me explain the rear ones are the same, but the two front ones are different names but the same size 205/50/16. would this cause the light to come on???? now when i get up i will change all the tires to the same size and brand (new ones), I'm just hoping that it would be the fix before i do the buy. i plan on using the r32 gtr rims they are wider, and with tires they feel way lighter, oh that's the factory rims I'm talking about. plus plus it looks so much better. I also went with the gtr fuel tank cause it plastic i noticed. witch i found interesting. i plan on installing the coil overs i got from the gtr alone some other items. like greedy boost gauge, HKS D Dragger muffler, seeing how the car is a 4 door i will need to lengthen the piping. oh and a FMIC, and Blitz BOV vented back in.
i would really like that 4wd light to go off and work right. is there a way to pull codes to see what the 4wd module is saying?? what if one day a speed sensor goes bad??? i would need to know how to retrieve codes from the module.
ok i just replaced all the tires using the gtr oem rims. the sizes are 225/50/R16 all round. but i drove it today and the light came on after about an hour of driving. i would cut the key off and restart the car and the light would go off, then after like 1 minute it comes back on. i would really like to know what approach to take to address this problem.
Now it may be the pump cause the car was converted to rear wheel drive and the pump ran for a while dry with no oil before the fuse was pulled. now i can just replace it with the gtr's pump. any ideas would help mate.
91h and 89v are the load ratings, not tyre height. Your two different front tyres may have been the same size, but just might have been different enough in rolling diameter to cause the fault.....even the same tyre, one new and one worn is enough difference. But as it turns out, that's not the problem, seeing as you get it with new tyres also.
ATTESSA computer under the parcel shelf has a flashing led for fault codes, or you can read them out through the Consult port with a decent scan tool.
GTSBoy thanks mate. i will look at the computer to get the codes. at least the parts that i may need would be right on that r32 gtr. i really did this swap to use the 4wd system so any help would be appreciated. i must say with the gtr's RS-R coil overs and fresh rotors along with the new tires made a world of difference with the car. i Love the way it drives. dropping the diff and changing the pump is no problem for me as well mate. that sounds like a 4 hour job.
to me i have the time as i'm not working right now lol. thanks again mate you the only one helping me out really.
Edited by MJTru
  • 4 months later...
The way you said the light came on after an hour of driving, then stop, key off/on and all good again sounds to me like the steering angle sensor.
Have you got an aftermarket steering wheel? That's the most common cause with the boss incorrectly aligned.
Car thinks you're turning a huge diameter circle and then after a while it throws a fault.
Most often seen when highway driving. (straight ahead)
As for the ecu, you've swapped over everything else from a GTR, may as well go for the Rb26 PFc too.
They're pretty cheap 2nd hand.
  • 3 weeks later...
Mate go put the gts4 metal tank back in. It has a swirlpot inside the tank where the pump sits. Also get an s14 snub nose clutch master cylinder because you will want a 30 in that thing soon and will need to do this anyway. Also with the awd light coming on and off check the resevior in the boot on the right side and make sure the levels are right and also make sure you bleed the rear nipple properly. Also check that the piston in the gearbox for the clutch packs is engaging properly and make sure to check the 4wd fuse in the box under the bonnet of the lefthand side in front of the strut tower is in correctly and not corroding. The exhaust will be about 150mm shorter of the rear bumper then normal. Your auto cluster is different from a manual gts4 manual gts4 is the same as gtr. With the diff ratios yes bang on the gts4 is 4.33 and are very strong. Many have seen over 800hp through them. The tail lights from gtr will go straight in the just have a little over hanging corner. Also nistune is awesome forget power fc. The capabilities and system retention of things like knock are very important and when/if you go rb30 it can be straight up retuned for that too.
  • 3 weeks later...
  • 3 weeks later...
Hi there again. Well i ended up damaging the rb20. Lol. But i just finished installing the rb26 in my gst4. I remembered to use the gts4 front diff insted of the gtr's. I changed all the harness under the hood all the way back to the fuse box by the drivers feet. Two plugs were different so i swaped out the pins and only noticed that one wire out of the two plugs were different but i placed it in the same location.
The fuse box and the whole harness in the engine bay was changed over. Im now waiting on my top mount manifold to reach so i can finish up the intercooler piping and down pipe. Im also looking for a clear insructions on how to install my power FC D jetro map sensors. I think looking from the japanese instructions that i have to tap into number 3 and 4 cylinder throttle body with a little air fitting on both sides. Them mount the map sensors with the smallest hose possible. am i on the right path here. Then i have to hook up the signal from the maps to number 1 and 2 amf inputs on the ecu main plug. Is this right.
Thanks mate.
Sorry man but just use the stock rb26 ecu with the loom and get a nistunr installed. Lot less fking round and retains knock and is capable of over 400awkw. Pretty cheap too and constantly upgrading the hard and software vs dejetro which is becoming out dated. Just my experience and 2c worth from it.
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
