im yet to put mine in too just need to get my fuel rail. Which fuel rail did you use to fit it under the plenum.
Anychance you could also tell me if the R34Neo injectors you pulled out were 11mm or 14mm. Seems to be two answers on the threads im reading.
Edited by B-rice
Just used the standard fuel rail and 4mm spacer man. It still clears the plenum easy as, no worries there. Ah to be honest i didn't even measure the size difference between the old ones and the new ones. I just sprayed lanolin on them and they went into the fuel rail fine and didn't move around at all when i put the retaining clips in. With my luck i wouldn't be surprised if i bought the wrong ones haha, anything i do seems to be one step forward and two steps back!
I've got my stock injectors sitting in a box at home, ill measure them for you tomorrow. Pretty sure they are 14mm though.
Sweet, cheers dude.
Also, new turbo finally arrived! It is much bigger than i thought it was going to be hahaha. It is going on tonight and is the last thing i have to get sorted before the car goes down to trent this weekend for tuning! Fingers crossed it bolts up all sweet and i don't have anything bite me in the ass >_<
Edited by iruvyouskyrine
Any idea what size studs I need? And how do I get the olds ones out?
Trying to make it fit by clocking the turbo but don't think it will work.
From memory the factory ones are 42mm, so it depends what size spacer you have. I think Stao uses a 15mm spacer, so you will need to get studs at least 15mm longer. I believe I went with 67mm studs.
Standard studs are 39mm, parts that protrude from the manifold is only 24mm, turbo housing is 10mm, spacer is 16mm.
So standard studs are 2mm Fromm even being flush with new turbo.
Will try and get it all sorted tomorrow, hopefully have enough time to get it sorted before this weekend >_<
This is what i would be after yeah? Hopefully can source some locally if not then i'm pretty much farked before this weekend haha.
http://www.sonicperformance.com.au/95015/Stud-_and_-Nut-Kit-GT30_or_GT35_or_GT42_or_GT45-M10x1.5-X-4/pd.php
Yep, they are what I used. Be warned, mine warped severely after about 2000kms. I had to cut two of them to get them off.
But MTQ were very surprised and said it shouldn't happen, and because I couldn't find any inconel studs I just used the same ones again. They seem to still be ok.
Got the turbo on finally after fighting with oil and water lines. Found it interesting that the turbo doesn't have a little nipple or similar to run to the wastegate? Just used a spare nipple on my plenum and run it to that.
Run the wastegate as close to the turbo outlet as you can. Stao really should put a nipple on the turbo. But you want the wastegate plumbed into a source as close to the turbo as possible, because of you get a leak somewhere and the boost pressure is lower at the plenum then you could be working the ass off the turbo, superheating the intake charge. If that means getting a nipple put onto the hot side cooler piping then do that.
Would probably be ok for the tune. You should really check for leaks before it goes on the dyno anyway, but hopefully it's ok. But if Trent can't do it, I wouldn't worry too much about it. Just do it at some point.
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
    • Which I agree with. I don't want or need a high hp straight line car, I want it to be fun on the road and nothing more. Hence why I said my max power goal will be around 500 crank. The few times I drove the car last year I didn't even use high boost and it was already quick enough for me, should have been around 380-400 crank I think (2860-5s at 1-1.1bar).
