301rwkw at 20psi? :P
Sonofabitch! :P
Over 9000
Well trents dyno said 301kw but my scouter did say over 9000.
Sorry for the small photos but its all I have at the moment. I understand that stao is currently pulling my car apart in an attempt to fix my boost control issues, which are pretty obvious if you look at the dyno graph.
Hopefully get it sorted before this weekend as I am travelling down to pick it up. But Trent and Cat are absolutely fully booked out. Does anyone know of any other tuners in Melbourne that are open Saturdays? All the idle stuff is done and its tuned for that boost plot currently. Will just have to get someone who knows what they are doing with a greddy profec b spec 2 to sort out the boost control and do a power run to check the tune is still fine.
  • Like 1
Right. Well I'm drunk at the moment but picked up the 32 today and holy shit it's an angry car! Made 312kw@20psi and it goes like a shower of shit. Will give more detailed results tomorrow.
Also, pics. Because everyone likes pics.
  • 1 month later...
So, been a while since the last update.
Basically i have been doing minor things since getting it back from trent. Stereo, gauges, tidy up wiring etc. Have done 2 drift days and holy shit it is a different car to drive.
Second gear is useless and third gear is now where it's at. Still have power steering issues that i am yet to fix.
Basically i am stoked with it and just need to drive it more often haha. Will update thread with more info/pics if people are interested.
Yeah went in no worries man. The paint on them was shit and started flaking off but apart from that it is all sweet. And a bottle of jimmy is the least i could do for the run around that Brad gave you!
http://www.youtube.com/watch?v=SdRv1bXTv04
  • 3 weeks later...
^ just paste the address into the WYSIWYG editor and it will do the rest :)
Also, how are the lines holding up from Kando? Mine arrived yesterday, but those idiots at the dim sim factory sent the wrong crush washers LOL
Yeah, i made sure that i did everything possible to help them out. My mates Subaru liberty (which sits lower than my car) seemed to be fine, don't know how they managed to f**k mine up so bad.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
