Running a precision and came with a 3 5/8 flange, which tapers down to 3" around the cat. I wouldn't go any larger than the exit of the rear housing, counter intuitive.
I'd only use v-bands where you really need the seal to be tight, they look cool but can be a bitch to line up and get back on.
This is what I got made up for mine, have little pipes to run as screamers or can be fully plumb back
And u gotta use teflon pushlok hose for e85
Edited by n_D
Looking good man. You must have been pumped if all of the Aeroflow stuff arrived at once! I have been ticking really similar goals off on my build. Looks like its all coming together!
Yeah it's so much stuff when it is all laid out on the bench like that haha. Pretty stoked with the progress at the moment even if my wallet is not.
Nice work as always, but just a heads up, you might want to think about upgrading to a 3.5" exhaust.
Hey man thanks, this is honestly something i should have thought about earlier but it is too late now. Plenty of people have made over 400kw with 3" (and mine is completely straight through, no mufflers/cat/resonators at all!) so i don't think it will be a limitation. Plus im not shooting for power like that anyway!
Will be going 4inch dump on mine, then 3 1/2inch back to help it breath..
The rear housing adapter Tao provides only has a 3" outlet so i don't need anything ridiculous, besides, it's too late now anyway haha.
Exactly right, no point in having 3" dump (as that is my exhaust housing outlet size) and a 3.5" or larger exhaust. I found the V-Bands pretty easy to align and get on, that was with two people though. One person might be harder but how often do you take your exhaust off? And surely you can find one mate to give you a hand hahah.
butterfly in exhaust is one thing im seriously thinking about. My car is loud and dont think my neighbors like me when i come home late night.
Exactly the reason i want one! I try to be as reasonable as possible as i know i wouldn't appreciate it. Unfortunately due to time and money constraints this idea was ditched, but it is something i would like to try and incorporate in the future. Once the car is up and running i will get something sorted, i think it is a pretty good idea for a common problem.
I know haha, I took it off the car (which was literally a 5 minute job, thanks V-Bands) just to take photos of it! And now it's off I don't want to put it back on because it looks so damn sexy! It bolts to the gearbox as well for bracing. And it sits so flush up against the body it's amazing, can't even fit my fingers between the top of it and the floor pan, running nismo mounts so it should be fine.
Exhaust also comes with a lifetime warranty, and was VERY reasonably priced. The work Dann does it absolutely top shelf, and backed by a lifetime warranty. I highly recommend to anyone!
My old exhaust was a stainless/mild mix and a bit of a slap together job. Was never loud enough for me, but I think this should definitely be loud. Left room to put a muffler/resonator in later if I want :)
  • Like 2
Very nice mate, good to see it moving forward.
May i ask as Im about to get my intercooler piping done, whats the thinking behind having the BOV on the turbo side and not the intake side? Or does it not really matter? I was going to get mind on the intake side, just after the throttle body
Looks good mate, some ear plugs will be needed i reckon, will be interesting to see how well it flows, hope those black silicon hoses don't blow out under boost though. Looks very clean and well done though.
  • 1 month later...
Thanks guys. Was getting so sick of working on it after all these moths, had really lost motivation to do anything and was hating it.
Finally got it mostly sorted and had a quick squirt around the block today. Put a smile on my face for sure! Was nice to have the car in the shed and walk away feeling happy about it :)
Just a quick photo as I put it away.
  • Like 1
Don't know anything about BOV's sorry man as I have never run one. Before this I used a cefiro crossover pipe which had no BOV provision from factory. And I'm not using one now :)
  • 4 weeks later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
