Hi folks ,
Very few I see r34 2 door drifters, love the look of em so I'm Very interested in drifting my r34 Gtt, it's still basically standard adpart from full turbo 3 inch exhaust system hi flow cat/muffler, boost t, 'Extreme'heavy duty clutch, and front I/c. And hsd coilovers.
Any suspension component work I have to do to get decent drift angles?. Lol..
I sort of wanna start with the power I have atm and can get enough skills to control the power. Then later down the track upgrade to bigger power.
..removed my hicas bar too .
R33's and R34's share suspension components and setup so what works in one would work in the other.
I would suggest that you start by coming along to a Texi day (there is one on 30 March in Sydney) to get the fell of your car going sideways in a safe controlled environment. There will a number of cars there and you can talk to other drivers about what works and what doesn't.
Then from that experience decide what mods you want to do first.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
    • Sounds like using one of those configs modern cars use where they turn off the whole headlight these days on the side that the indicator is flashing on.
