R34 Auto N/a Sedan Performance Upgrades?
junb
 Share
Hey guys i just bought a r34 sedan auto, i'm buying new rims this week and getting it lowered, getting a full exhaust upgrade, just wondering for those who live in melbourne where is a good place to get a dyno tune and how much am i looking at cash wise which is still no problem just curious on the approx gain i will be expecting?
To be blunt, it's not worth doing all that many performance mods to an auto N/A skyline. You'll never get value for money.
Are you going an aftermarket ECU? A nistune board (which you can't have put in an R34 Rb25 ECU) would cost the best part of $1000 to have installed and tuned and I'd be very suprised to see more than an 8-10kw increase, if that.
Edited by Truffles
yeah i heard everyone say the same thing that there is no point upgrading performance on a n/a skyline but in the end of the day it will be turbo one day since i am 22 and i would just like to slowly enhance its performance for when i get to the turbo stage. Money wise also isn't a big hassle since i do work and have saved to spend money on this car without breaking a sweat.
Much smarter and cheaper to upgrade a GTT, there are a lot more differences between a GTT and GT than just a simple turbo. Save your money and buy a GTT mate.
  • Like 1
It's not about money being an issue, it's just about being smart about your money. By the time you've finished upgrading everything, you could have purchased a GT-T manual coupe that will be faster for cheaper.
There's not much point in spending all this money on your N/A if you want to turbo it in the future.
The best choice (money wise) is to keep the N/A stock, save more money and then when you want to then upgrade to a modified GT-T.
I have a r34 gts manual coupe. And I really don't want to have to find a complete new whole car since graduating to my full licence, so being that I'm still very interested in a turbo.
Is my best bet buy and rb25dett and slotting that in place of my neo 6 rb25de.
Or buy a more costly better aftermarket turbo manifold accesories ect ? And bolting on and tuning ?
Not really sure about the r34, but in the case of the r33, the turbo version comes with bigger brakes, stronger gearbox, 5 stud hubs, lsd. So while people might want to keep the car they know, the cost of turboing a natro properly will cost roughly the same as buying a whole turbo vehicle.
Thank's guy's i won't work on the performance of my car just replaced the rim's and got it lowered looking to put in a new full exhaust system in the near future and i will just replace all the stock speaker's and not get sub's but yeah when i am full licensed i'll just import a gtr. Overall i am happy with the way my skyline handle's corner's at 90km without sliding out. Everyone gave me grief before buying this car saying it will be crap because you will have to pay to much for insurance ect ect,I barely payed over $500 for insurance, rwc and car transfer. I am happy i stuck with what i love which is a nissan import and not a ford or commodore.
  • 1 month later...
not just that the compressions in the NA and turbo engines are different, you cant just add a turbo to a NA engine with a tune and expect it to perform the same its always going to be sluggish and it would have been better off staying NA.
im in the same position as you, restricted license and i have a NA R34 GT-4, im more then happy with the car in every way for now and was considering a RB26 upgrade when i get off a restricted license because ive spent over 10k extra on my car already and am fairly attached to it but its just not worth it, in the end ill have to sell to get a turbo but knowing a GTR will follow wont make it to hard ;)
You will actually find that a natro with a turbo booked on will put out more power and be more responsive than a factory turbo at the same boost level because the natro runs higher compression. The issue us that a natro with a turbo will be more probe to pinging/detonation so you are restricted by how much boost you can run before it starts to ping, which will be lower than what you can run on a factory turbo engine.
  • 3 weeks later...
do remember these motors have a turbo for a reason, a 2.5lt gutless reason. if its n/a for power its a v8. yet even a stock turbo is slow. hence why we modify
 Share
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
