These are the last few parts I need to sell after selling my shell. I can do a heavily discounted package deal if somebody is looking to do a RB26 conversion to a GTST. All the parts are there minus one AFM. Will do package deals on other parts also.
I've sold probably over 100 parts on this forum over the last ten years of owning several skylines. All of the original SAU crew know me well. Everything for sale is a genuine sale. I'm not here to rip anybody off. Its the end of an era for me once these sell but it time to move on to other interests.
Located in south end of Melbourne. I do head towards the city and SE very oftern if you would like to meet.
Note: There aren't any other parts for sale so please don't pm me asking.
$3500
RB26DETT engine with now confirmed N1 pistons (good for 600hp), adjustable cam gears, complete intake and exhaust side. All genuine covers.
Sump is currently removed for viewing. Only removed due to parting out car. I have a new set of exhaust side gaskets.
$1300
Garrett turbos 2560-5 with adjustable actuator. Great condition and only ever run at 14psi due to standard injectors
$1750
OS Giken triple plate push clutch and flywheel. Only minimal wear. Great clutch for a track car/daily. These retail for $3000. Will fit RB20 and RB26
$200
Excedy button push clutch. Lots of meat left. Includes standard flywheel. Will fit RB20 and RB26
$1800
Buddy Club P1 QF rims 18x10 +12. R34 GTR offset
Hankook S1 evo tyres 265/35/18
These are the second lightest wheels in the market that a forged aluminium without magnesium added. $900 each new.
If your serious about track performance their well and truely worth checking out. Less gyroscopic inertia and less sprung mass.
$750 Brake Upgrade - Fits R32/R33 Gtst and GTR except R34
New 324mm slotted front rotors and slotted rears.
Braided lines with all metal fittings
UAS 324mm front brake caliper spacers
Recently reco'd calipers, seal kit, measured pistons, stripped and repainted red.
Castor rod air deflectors.
Several sets of half work pads - DS300, EBC blue, red etc
$200
100mm FMIC made in Japan with mounting brackets. Cast end tanks
$200
Defi boost gauge and control unit - Black face
$80
TRUST hard pipe - Fitted with 2 injectors. RH chassis to intake.
List of R32 GTR and RB26DETT parts....
$250 Genuine TRUST Gracer side skirts - Bet looking and quality skirts on the market. Over $1000 landed new.
$125 Radiator and shroud
$125 Starter motor - will fit R33
$125 Alternator
$200 Standard instument cluster with Nismo 320kmh speedo
$100 Resistor pack for GTR injectors
$200 Engine loom from ECU to motor
$40 Lower standard intorcooler support brackets
$100 Consult - Engine diagnostic display interface
$100 Standard RB26 turbos and actuators. They have been removed for 5 year. Spin freely but no warranty
$75 AFM
$100 All the airbox - intake and intercooler pipes from the LH engine bay
$150 Blitz ECU RB26DETT
Edited by Rowdyr32
  • Replies 44
Posted Images
Paul (Silkgoid) I still have the -5 turbos available.
Ddrgtr7 I've pm'd you.
Also have.....
Set of 4 18inch Michelin Pilot slicks for $150 firm with 2-3 trackdays left in them.
Front and rear Cusco strut braces to suit R32 GTR/GTST $200ono
GTR FMIC Sold. Thanks drgtr7 for the quick and easy sale.
Thats a few sales with what seems to be the now "old school" way. Appriciate it Silkgoid and drgtr7. They asked for my phone number. Talked to me. Negotiate a price. Organise a time and place to pickup the item. Met on time with the correct cash. Perfect!!!!! Thats how to do it kids....
All this without saying you'll buy it in the first message. Then offer 1/3 the price 20 messages in??? Dreamers.....
May consider selling cam,rocker and coil pack covers seperately as a set along with sump/diff and whole complete intake side if anybody is interested.
Attached is a picture of the braided lines still attached to the calipers. They have minimal kms on them.
I'm willing to sell them seperately.
Edited by Rowdyr32
Thanks for that, any chance of a pic of the back of the caliper? So I can see the metal line?
How much would you be looking at for just the lines?
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
