2001 VSPEC II in perfect condition. Sensible modifications and a perfect all round package. You will not find a better one for sale.
KMS 60600
ENGINE MODS
APEXI POWER FC
HKS GT-SS TURBOS TOMEI EXPREME TURBO MANIFOLDS
POWERHOUSE AMUSE TITANIUM EXHAUST
HKS FRONT PIPES
TOMEI PONCAM CAMSHAFTS
TOMEI CAM GEARS NISMO INTAKE PLENUM
NISMO Z-TUNE INTERCOOLER
NISMO OIL COOLER
NISMO HARD PIPING INTAKE
NISMO TIMING BELT
NISMO 600CC INJECTORS
NISMO AFM
NISMO FUEL PUMP
NISMO SPARK PLUGS
NISMO COPPERMIX CLUTCH
ARC AIRBOX KOYO RADIATOR
ARC OIL CATCH CAN
SUSPENSION NISMO S-TUNE HA COILOVERS
WHITELINE REAR 24MM SWAYBAR
AUTOSELECT STRUT BAR
BRAKES AND RIMS
NISMO LM-GT4 18" WITH NISMO LOCK NUTS
BRIDGESTONE RE-11 265/35/18 (BRAND NEW)
ALCON 6 POT BRAKE KIT WITH 365MM ROTORS APP STAINLESS BRAIDED LINES MOTUL 5.1 FLUID PAGID FRONT BRAKE PAD ENDLESS REAR BRAKE PADS
BODY
CARBON BONNET WITH NACA DUCT REAR
UNDERBODY CARBON DIFFUSER
ORIGINAL NISMO S-TUNE FRONT BUMPER
NISMO SIDE SKIRTS
NISMO REAR PODS
JUN STYLE CARBON WING EXTENSION
REAR BUMPER DIFFUSER
GANADOR CARBON MIRRORS
INTERIOR
NISMO 320KM/HR SPEEDO
HKS EVC-5 BOOST CONTROLLER
APEXI TURBO TIMER
Also have spare N1 Block for sale which can be negotiated.
Next step will be for someone to build the engine.
Reason for sale. Looking for a european sports car.
Welcome to any mechanical or body inspection.
post-9099-0-74091500-1362455083_thumb.jpgpost-9099-0-25163300-1362455088_thumb.jpgpost-9099-0-01706200-1362455098_thumb.jpgpost-9099-0-99344800-1362455106_thumb.jpgpost-9099-0-53150400-1362455125_thumb.jpgpost-9099-0-38703500-1362455570_thumb.jpg
Ad on carsales. http://www.carsales.com.au/private/details/nissan-skyline-2001-14394353?base=1216&vertical=Car&cr=0&eapi=2&__N=1246%201252%201247%201282%204294963846%204294963593%201216&find=HNB|CarAll&silo=Stock&num=15&sort=default
PRICE $63,900
May consider swaps for M3, RS4, 911 Turbo with cash adjustments.
Heuson
0433093555
Heuson you're killing me! I wanted this car so badly last year when Jason was selling it and you beat me to it by a couple of hours, now you're already getting rid of it for a euro car and it hasn't even been a year!!
Would you swap for a widebody R33 GTR Vspec with cash adjustments?
'traitor'! You prefer the R33 GTR, remember? jk
You'll end up with "R33 GTR Withdrawal Syndrome!"
jk
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
