Hey guys,
I have a Series 2 R33 GTST which i have fitted a few mods to but my latest is the Profec B Spec II due to getting it with all wiring for $120. :D
Issue is (being honest here) i have no idea how to set my "gain, set gain" etc.
I have the boost set where i want it (7 on low and 11 on high) but it seems to come on boost alot different between the settings...
Does anyone have some settings in theirs that i could have so i can get mine right..or an idea on what i should set it to?
Cheers
Ben
https://www.sau.com.au/forums/topic/421132-greddy-profec-b-spec-ii/
SET is how much boost you want to run (which isn't in any scale of bar or PSI, in some weird %)
GAIN is the duty cycle, how hard you want it to come on.. ideally I just wind this sucker up to about 20 and if there are spikes just slowly drop it till the boost is nice and flat
Not too hard to setup, if you're around Sydney I can show you how to do it and also set it up for you for a 6 pack of beer hahaah
I'm not looking at getting it tuned just yet. New turbo has to go on first ( just waiting on some cash for the lines,gate and manifold) but i'll hit Jez up and see what he can do for me.
Good plan, Jez is the man! lol
John, the percentage is the amount that the solenoid will open to release the pressure in the wastegate tube. So 20% means that the solenoid will open a fifth of the way to bypass the pressure on the wastegate actuator and release
it into the atmosphere.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
