just wanted to let people know about the drama I had yesterday with my adjustable arms in my r33. I just got the car from pedders after they did the steering alignment I got about a 100m down the road when the threaded bolt on my rear lower control arms stripped straight out causing the traction control and toe arms to bend and buckle leaving the wheel hanging on by just the half shafts just proves to buy the top name brands I got the off a guy on this form so I don't know the brand ill put pics up if I can workout how to just wanted to let people know to be careful I have ordered ikeya everything hopefully else goes good
  • Replies 50
Put up pics of carnage so we can tell what brands, style and if they were done right to start with?
I have had cheap arms in my car with 480rwhp and they have been OK, i HAVE broken the welds on the rear traction rods due to the shitty design but they have a design that doesnt allow it to snap off!
More detail and pics please :/
can I put pics up with iPhone?
it was the lower control arms thread that connects to the ball joint bit that literally ripped out that caused all of the problems
I don't think power played much part as I didn't even get to full boost and it happen when I was slowing down at about 20kph
now there is another drama the front lower control arms are hitting the disks now I'm pissed off brand new Dba 4000 in the bin
I sent the guy I got them off a pm to find out the info on them
Good idea... Cheap chinese arms are all pretty similar and they are sold by so many! So find out where they came from and go from there...
Formula Ikeya. Expensive and good.
But this whole thing is one of the reasons why these things are not road legal.
that's true
There is no sign of damage on that thread. So either a totally wrong size thread was supplied, and not noted by the installed, or it was not installed properly (ie adjusted out way too far).
Either way it is not a problem with the arm itself.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
