So a friend recently purchased a R33 GTS-T, he's taken it to the pits to find out what needed to be done to get it registered it the ACT, unfortunately, they picked up that the chassis rail is damaged.
Question is, has anyone experienced a damage chassis rail and the cost in getting it repaired?
He doesn't know the extend of the damage yet.
It's booked in next week for assessment.
Cheers for your opinions.
https://www.sau.com.au/forums/topic/421143-damaged-chassis-rail/
* Sometimes the rail is irreparable > replacement of the rail OR the car can't be blue slipped
* Sometimes the section can be boxed > welded
* Sometimes a hole can be drilled through the rail > threaded > pulled down
Booked in for next week. Fingers crossed it goes well.
The RTA did say it's repairable (Whether or not he knew what he was talking about), but hopefully it is repairable, that's my main concern atm.
(OP is referring to me).
What came back as so expensive? what did they say?
It's not on paper as of yet because he didn't quote the parts (He had to ask Nissan), however, the 2k so far is for the labour, enlightenment machine ($500) and signing the paper for RTA ($500). The quote isn't down on paper due to the quote unfinished
, but I need 4 segmented parts, which is an unknown cost atm.
It feels retarded, but cheapest in town apparently. I didn't notice the damage, but it's pretty bad. What is more retarded is that the car drives perfectly fine and perfectly straight. It's just the RTA being dogs.
Does this car still have valid registration in another state? If so, which one?
+1 for pics!
It has 1 month in NSW Rego.
Once the lad gets the full quote he will send me an e-mail with everything. He just needs to make a phonecall or two.
I'm pretty much seeking a R33 SR2 rolling shell as of now, unless the quote is going to be cheaper then I expect.
Don't NSW cars need to be inspected for rego renewal? where as in ACT they can just randomly call for an inspection?
Change of ownership I'm guessing is mandatory inspect in ACT & NSW aswell. (Jeremy only just bought it)
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
