How's it? I have myself an RB20DET, It has FMIC, T04/T3 turbo, LTx12 microtech, Bosch 040, Malpassi rising rate fuel reg. Now the dillema I am facing is that I have Rx7 non turbo injectors fitted (460cc). The tuner had to run the car rich at idle due to dropping the cycle 1msec caused the car to hesitate and hunt. This is what he told me. This is causing problems, shitty fuel consumption as 90% of my driving is fairly local and the excess fuel seems to be washing the bores. The RB has been rebuilt and I think the overfueling is causing more damage than good. The tuner recommends that I drop injector size, so I have got my hands on a set of CA injectors to fit as they about halfway between stock (RB20DET) and what I have now. I am afetr opinions should I 1/Get him to try again with the 460cc's? or 2/Get the CA injectors cleaned and flow tested and fitted/tuned? What do you think? The tuner is fairly well respected as he has the Ford (hahaha) performance contract doing the new turbo falcons and v8's. Thanks for your opinions Pete
https://www.sau.com.au/forums/topic/42116-rb20-injector-dillema/
hi OMP,
don't know if u saw my reply in the other thread where u posted, so here goes -
i'm running 550cc injectors on my RB20, ECU is AP Engineering PFC. Injectors have gone up just over 100%, but my tuner has done an awesome job with the staging, idle, etc - tuning work. Running a HKS GT2530 turbo, and I only run around 1 bar of boost so we're probably talking about a similar power range, tho I'm probably making less power heheh. I don't think the injector size is too big - my 550cc injectors are bigger than yours and with careful tuning, I even have excellent fuel economy on highway (230kms on just half a tank) and acceptable town consumption - 250-350kms. perhaps there is some issue with the specific injector itself? lag time or something? I don't know much about injectors :)
Whats the Microtech like? I am saving for one of these at the moment, and will be running a similar setup, but with GTR cams, exhaust manifold and GTR injectors
I am going to get the LT-12S though, but interested to hear what your experiences are
Chris
P.S - from every big injector/programmable computer setup I have ever seen with Idle/low speed problems, it always comes back to the tuner. Was it tuned via hand controller or via Laptop? Freebaggin has a LT-12 in his R33, running 280rwkw, and has just recently had a retune utilising the Matrix mode tune, and from all reports it drives really well now, maybe PM him
ill tell you what wont help.... i was going to use some rotary injectors in my rb20 untill i realised a major factor.... rotors love fuel... the more u give em they just keep going .... any rotor injector had basically no or just a really crappy spray pattern.....therefore they arent really suited to a piston engine.... so i went for gtr injectors myself and the 4g63 are another good option.....im not saying u made a bad decision but what i am saying is that it makes it harder to tune idle/low revs and also i use about 35 psu fuel pressure thats about all u need...... get everything else sorted dude then maybe try amd gtr or similar injectors....this is just the opinion i have formed after listening to several ppl in the know and trial and error im not saying im 100% correct...9but i hope i am :D )
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
