How's it? I have myself an RB20DET, It has FMIC, T04/T3 turbo, LTx12 microtech, Bosch 040, Malpassi rising rate fuel reg. Now the dillema I am facing is that I have Rx7 non turbo injectors fitted (460cc). The tuner had to run the car rich at idle due to dropping the cycle 1msec caused the car to hesitate and hunt. This is what he told me. This is causing problems, shitty fuel consumption as 90% of my driving is fairly local and the excess fuel seems to be washing the bores. The RB has been rebuilt and I think the overfueling is causing more damage than good. The tuner recommends that I drop injector size, so I have got my hands on a set of CA injectors to fit as they about halfway between stock (RB20DET) and what I have now. I am afetr opinions should I 1/Get him to try again with the 460cc's? or 2/Get the CA injectors cleaned and flow tested and fitted/tuned? What do you think? The tuner is fairly well respected as he has the Ford (hahaha) performance contract doing the new turbo falcons and v8's. Thanks for your opinions Pete
https://www.sau.com.au/forums/topic/42116-rb20-injector-dillema/
hi OMP,
don't know if u saw my reply in the other thread where u posted, so here goes -
i'm running 550cc injectors on my RB20, ECU is AP Engineering PFC. Injectors have gone up just over 100%, but my tuner has done an awesome job with the staging, idle, etc - tuning work. Running a HKS GT2530 turbo, and I only run around 1 bar of boost so we're probably talking about a similar power range, tho I'm probably making less power heheh. I don't think the injector size is too big - my 550cc injectors are bigger than yours and with careful tuning, I even have excellent fuel economy on highway (230kms on just half a tank) and acceptable town consumption - 250-350kms. perhaps there is some issue with the specific injector itself? lag time or something? I don't know much about injectors :)
Whats the Microtech like? I am saving for one of these at the moment, and will be running a similar setup, but with GTR cams, exhaust manifold and GTR injectors
I am going to get the LT-12S though, but interested to hear what your experiences are
Chris
P.S - from every big injector/programmable computer setup I have ever seen with Idle/low speed problems, it always comes back to the tuner. Was it tuned via hand controller or via Laptop? Freebaggin has a LT-12 in his R33, running 280rwkw, and has just recently had a retune utilising the Matrix mode tune, and from all reports it drives really well now, maybe PM him
ill tell you what wont help.... i was going to use some rotary injectors in my rb20 untill i realised a major factor.... rotors love fuel... the more u give em they just keep going .... any rotor injector had basically no or just a really crappy spray pattern.....therefore they arent really suited to a piston engine.... so i went for gtr injectors myself and the 4g63 are another good option.....im not saying u made a bad decision but what i am saying is that it makes it harder to tune idle/low revs and also i use about 35 psu fuel pressure thats about all u need...... get everything else sorted dude then maybe try amd gtr or similar injectors....this is just the opinion i have formed after listening to several ppl in the know and trial and error im not saying im 100% correct...9but i hope i am :D )
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
