selling a couple of sets of wheels and some other bits
located on the sunshine coast for pick up
text me whenever ** 0434282866 **
open to swaps for 32/gtr/cefiro/86 parts, if you would like to negotiate a price just hit me up.
selling my 18" Sparco NT wheels off my R32, fronts are 8.5 rears are 9.5 both 38 offset i think. these wheels are getting real hard to find (especially in black) and they are quite OG. LHS has a bit of gutter rash nothing serious, RHS almost none, paint in very good conditon
235/40/18 dunlop sp sport 300 tyres all round 50% on three of them, one of the rears has the outer edges worn.
wheels were almost 6k new. 5x114.3
asking $1600
will come with the special little wheel nuts and tool. as well as all four mint sparco center caps (which are quite cool) and a little slip on spacer i was using on the front
Selling the bosses rotas rbx i think they/re called
17x9 -13 (x2) and 17x9.5 -19 (x2)
very good condition on drivin on a few times, very light gutter rash on one
4x114.3. 80% tread on tyres (goodyear 215/45/17)
asking $1100 (missing one center cap)
selling an rb20 mostly complete, has manifold no turbo/lines
ran fine before it pulled out. basically a long motor with injectors/line
rocker covers just painted in wrinkle red
$250, will split covers (they do have breather fittings) make an offer
selling TRUST intercooler with piping to suit standard set up. $50
also i have an r31 runs well drives good. no interior and body is a bit beaten up, head lights and bumper ok (series 3) would like to get rid of entire care $700, but make me an offer.(its manual)
  • 4 weeks later...
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
