Ok so pending photos ill take bonnet, right guard, front bar reo support if for sale, front right xenon if for sale. I need the piece that holds the right side of bar up a little metal piece goes from edge of front right bar to just under headlight. And the piece that goes along the engine bay at the edge to bolt the right guard down down has a little rubber deal on it.
  • 1 month later...
hey all, sorry i have been away for a while. however. the stag has been sold. only parts i have left are:
coilovers for rs4s f13kg, r9kg and 24x damper adjustable $700 done maybe 3000km if that
power fc from r34gtt inc HC also works on neo stageas an very few s1 stags $1000
apexi pod, like new $80
rb26 carbon fibre timingbelt cover new $40
stagea front strut bar $40 also fits r33 and maybe r34
a factory cut black bumper bar, has broken clip on one side. can be used to clear defects use for drift, race and on road etc $ a handshake and hello will do
  • 3 weeks later...
  • 3 weeks later...
hey all, stagea sold in one piece, all i have left are exhaust, coilovers and a apexi airfilter.
sorry for the late reply.
Steve - coilovers werent too harsh but pretty stiff, but added a heap more grip.
    • Yeah been doing it in an x shape. Do you reckon it's worth putting guide coat early where the filler isn't sanded down completely smooth? Reason I ask is because as I'm sanding it one part might be level which I don't need to sand anymore but the other part might be high so I can just focus on that instead of sanding across the whole repair area. I wonder if the putty is too thin, though the area is almost completely smooth before I do it as I've already put filler prior.
    • Just 2, and inline. One switch temp related other switch driver controlled.   I'm nearly in my head back to Arduino land for it...
    • Complex conex, sand in X shape. And don't go hardcore. I find putting on filler to be the art here to help.
    • Hey y'all, I have a completely stock 1991 R32 GTR, yesterday I took my car out and went for about a thirty minute drive. It was fine on the way there but when returning home I think the car might have gone into a limp mode. I was cruising in 5th gear around 130km/h, the hicas light came on and there was a significant loss of power. About a minute later I hear a thump, the car starts driving normal again and is fine the rest of the drive back. This is the second time its happened, same as now it was fine on the trip there. On the way back it had the hicas light on but that time I would feel the power going in and out before hearing the same thump and it being fine.  I have no idea idea what causing this, but if anyone has any ideas it would be great as a start chasing the cause of this. Also I can provide more details if needed. Thank you
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
