Hi all just cleaning out my shed of used parts that I had and was holding onto but now that I am selling my skyline I no longer need these anymore. I will try and explain everything as best I can but looking through some of these parts even im not sure of some of them.
- Nissan R34 Service manual all in english very good condition. $60
- Nissan R32 centre dash cover with cigarette lighter $20
- standard fuel rail RB 26 $30
- under body sump bash guard/ cover $20
- standard RB 26 camshafts ( Not Tomei don't be fooled by box! the tomei poncams are in the car) $30 for the pair
- clutch fan shroud $20
- HKS BOV'S suit GTR $50
- BOV Pipe clear large $15
- Hicas lock bar red??? unsure exactly what it is $20
- Random assortment of piping and hoses range of sizes $15
- Used Injectors (not sure of size just says A46-00 JECS) $90 for all six
- turbo exhaust manIfold heat shielding RB25? $ 15
- Brake master cylinder used condition $20
- Nissan ECU possibly R32 GTR? Looks ok $50
- R32 Dash vent brand new nissan genuine $30
- Interior light assembly unsure of model $10
- Blue wheel spacers???? really unsure of this one anyway they are all brand new and there are 8 of them $40
- Used wiring harness R32 GTR RB26 ok condition $70
Im having trouble uploading photos will add them as soon as I can or alternatively you can get me to email them to you.
Tried to describe everything as best I can call jack on 0409 217803 OR [email protected] I am located near Maitland N.S.W.
You are better off trying to reach me by phone as I do not always have access to internet.
Cash on pick up preferred or direct deposit. Alternatively you can buy everything listed here 1/2 price $280 for the lot not including postage.
Edited by Quigs
hey mate can you do me a favour? the jecs injectors... can you look on the top of one. there should be two numbers. could you pm me the numbers so i can run a part number check? thanks mate.
  • 4 weeks later...
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
