No holds and no shotguns, nothing is sold till it's paid for or a deposit is put down.
I can ship anything anywhere if you pay for it. Pickup is available no probs.
6x Nissan Silvia/200sx s15 coilpacks
Price: $50 each
Price drop: $200 for all 6
I took a pic of 4, but I have 6...
EVO 6/7/8/9 brembo rear calipers with pads and lines
Price: $320
Price drop: $280
Price drop: $220
JDM HEKTIK Y0 - Auto Service MATSUFUJI s14 clutch pedal brace, may fit s15 and s13 but I don't know for sure.
This braces the clutch pedal bracket and stops it from flexing; is a good mod for those that run tuff clutches or likes to kick it once in a while. Stops the flex and stops the pedal bracket from breaking.
BRAND NEW
Price: $80
Price drop: $60
Genuine WORK equips 3 piece wheels
19" x 11" -12 offset
Super deep deep deep dish
Includes 2 wheels
Includes 2 centre caps
Includes 2 BRAND NEW achilles ATR SPORT 245/35/19 tyres
Price: $1500
Price drop: $1350
rare Genuine Nissan Silvia/200sx s15 FULL COMPLETE SET of locks, barrel and 2 keys
Selling as a set, will not separate
Price: $280
Price drop: $230
Price drop: $200
Price drop: $170
Genuine HKS and Nissan turbo gasket set to suit SR20DET.
Genuine HKS studs and nuts (these fell out of the packaging and you can see them in the plastic bag beneath):
Brand new.
Price: $50 the lot, not splitting
OEM s15 aus spec carpet, good condition
Price: $100
Price drop: $80
Nissan rear DRUM BRAKE refresh kit - this is all brand new genuine nissan OEM parts:
Price: $120
Price drop: $100
S15/s14 Apexi PowerFC with hand controller and extension cable
It was new but I can't find the box but I still have all the documentation and instructions and paperwork. It's out of an s15, but I think with an apexi patch loom it'll fit s14 as well???
Hand controller is in great condition, the actual ECU itself has a few velcro spots stuck on which can be easily pulled off but otherwise in good condition too.
This is in great working condition.
Price: $850
4x Nismo 740cc installed in an s15 fuel rail, with fuel pressure reg, the rail itself, some hosing, and 4 brand new electrical plugs as well.
These were brand new and comes with the genuine nismo boxes and paperwork.
Price: $500
4x s15 OEM 480cc injectors
This is in great working condition when taken out of the car, should still be since it's been sitting in the zip lock bag.
Price: $200
Brand new genuine Turbosmart 4" straight silicon
Price: $10
2x Brand new genuine Bosch 044 fuel pumps
Price: $370 the pair
Other info:
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
