okay ill start with what I know I'm doing
ill be running a custom sump fully baffled and wing gates, head return, with an external pick up point and modify the pump for external pickup
now what I'm not sure is what pump and collar to use I heard of the new nitto pump with the splines haven't heard of anyone using it on a rb30crank and well that's basically my question what pumps have people used in the 400-500kw+ range on a 25/30 I just want to know what people have used and there advice don't want to know what people have 'heard' and before anyone says to do a search I have so many times it varies so much just want a bit more info before I buy something
https://www.sau.com.au/forums/topic/421189-oil-system-ideas/
Well from those links it answers your questions
1: Tomei is best/better by design - spline drive
2: Nitto doesn't have a spline drive available for sale yet.
3: Jun and nitto pumps will suit your power outputs. Plenty of more serious powered cars running those pumps.
4: limiter bashing will kill all pumps.
JUN, TOMEI and even HKS were all the options until NITTO came along.
NITTO seems more readily available as its 'local'
You can even just use upgraded billet gears for a standard or N1 pump.
Edited by jangles
yeah I thought about a external do I have to go dry sump if I go that way??
Nope, wet sump can be done.
Brad (RISKING) of pro fabrication does an external wet sump with reservoir that's well priced!
It may look like a lot to start with, but by the time you add everything up with a normal pump setup it's not that much..
$1500 pump
$1500 sump
Edited by jangles
If i were to build another engine this would certainly be high up on the choice of oil pump setup for me...
By design yes.
Many 1000hp gtrs have run JUN and nitto.
Why are you Doing external pickup?
new design that Etm is doing it allows there to be a full gate without the pickup being in the way he just modifies the pump to use the outer port and blocks up the inner port and welds on a speedflow fitting to the sump and that's it
Air conditioning can be retained with the external oil pump system I've been doing.
Mine is far better than any external oil pump system currently on the market. It eliminates the surge issues as well as the broken pump issue.
It's half the cost of a complete dry sump system.
I've done about 6 systems now all of which have been tracked and driven hard.
A 2 stage pump feeds a surge tank arrangement in the same way a fuel system operates. Tank design has been the key to making the system work due to oil airation.
Ɨ
Ɨ
