new design that Etm is doing it allows there to be a full gate without the pickup being in the way he just modifies the pump to use the outer port and blocks up the inner port and welds on a speedflow fitting to the sump and that's it
Seems pointless as many, many, many cars are tracked, dragged, street driven with internal pickups.
I'm getting it all done for a good price sans if not cheaper then a asr
and if you think about it there's probably less work you don't need to extend the pickup and get it in the right position and when the gates and baffles go in you don't have the pickup in the way it's just a straight farword winged gate
  • 3 weeks later...
external pickup is what I have done, I have a box welded in the center of the sump with a pipe from that to the side of the sump with a AN-12 fitting all welded together then a AN-12 braided hose to the port in the side of the oil pump
it's a shorter, smoother run and the oil isn't running through a hot block gathering any extra heat soak and was alot easier to set up then a custom internal pick up and the ID size of this setup is bigger then the feed through the block, I opened up the side of the oil pump to except a bigger fitting then the 1/2" npt fitting thread the Nitto pump has so I have a minimum ID of 16mm
the hardest thing on this setup was drilling a hole through the A/C bracket so I could keep the A/C
that's exactly what I'm doing and you just helped out heaps I was trying to work out how to keep the ac iv just started a little fabrication shop from home so iv been flat out on other cars at the moment and haven't got to mine hopefully ill get to work on it soon
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
