Hey folks,
I've tried using an online compression ratio calculator to work out what headgasket thickness I should be going for but its not making any sense (probably my stupidity). The basic spec of the build is as follows:
R32 Rb25DE with HKS2535/GTX3071 hybrid
GTR crank, rods and pistons
Nothing skimmed
I'm aiming for a massively responsive 450 on pump fuel. Can anyone advise what gasket thickness to go for or at least what CR I'd get with this set up on a standard head gasket so I can work it out?
Cheers.
https://www.sau.com.au/forums/topic/421199-head-gasket-choice/
CR wont change much, but your Quench will. id use a stocker. or a similar sized mls, the stocker is 0.9 i think. Ive got a multilayer rb25 metal MLS gasket for sale (used once), has it doesnt work on my 30/25 build. for $50 if you need it. it measures at 1.1 i think. pm me if ur interested.
Edited by SilverECR33
If you have an MLS gasket the block and head need a near perfect flat finish. If you haven't touched the mating.surfaces then it might not seal. If you have a normal gasket you might get away with it but I'd still like to finish the block surface if it was me
The block and head have been checked and are flat from all angles that we tried. All the standard gasket material has been cleaned off so I'm happy it will seal. Im still trying to work out what CR i will end up with from either a 1.1mm or 1.5mm gasket though.
Can anyone tell me what the piston dome volume for a standard RB26 piston is? Ive also got a piston crown to deck measurement of 3.7mm, is this common?
Thanks for taking the time to respond lads.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
