Hey folks,
I've tried using an online compression ratio calculator to work out what headgasket thickness I should be going for but its not making any sense (probably my stupidity). The basic spec of the build is as follows:
R32 Rb25DE with HKS2535/GTX3071 hybrid
GTR crank, rods and pistons
Nothing skimmed
I'm aiming for a massively responsive 450 on pump fuel. Can anyone advise what gasket thickness to go for or at least what CR I'd get with this set up on a standard head gasket so I can work it out?
Cheers.
https://www.sau.com.au/forums/topic/421199-head-gasket-choice/
CR wont change much, but your Quench will. id use a stocker. or a similar sized mls, the stocker is 0.9 i think. Ive got a multilayer rb25 metal MLS gasket for sale (used once), has it doesnt work on my 30/25 build. for $50 if you need it. it measures at 1.1 i think. pm me if ur interested.
Edited by SilverECR33
If you have an MLS gasket the block and head need a near perfect flat finish. If you haven't touched the mating.surfaces then it might not seal. If you have a normal gasket you might get away with it but I'd still like to finish the block surface if it was me
The block and head have been checked and are flat from all angles that we tried. All the standard gasket material has been cleaned off so I'm happy it will seal. Im still trying to work out what CR i will end up with from either a 1.1mm or 1.5mm gasket though.
Can anyone tell me what the piston dome volume for a standard RB26 piston is? Ive also got a piston crown to deck measurement of 3.7mm, is this common?
Thanks for taking the time to respond lads.
