Got a BNF27Z – 22mm front adjustable sway bar, suits WGNC34 Stageas (4WD)
Been on my car for 6 months or so, made a big difference compared to stock, but I still have a bit of body roll when drifting, so I want to go up in size.
I also have a BNR11XXZ – 24mm rear adjustable sway bar that will suit both RWD and AWD Stageas, as it's designed to suit the automatic cradle (I have a S14 unit in mine ... same as manual). these would come with the endlinks to make them work too.
Happy to swap the front for a 24mm sway bar if anyone wanted to go down in size.
Front sway bar $200
Rear sway bar $220
Both for $400.
Located in Liverpool region, NSW
Happy to ship at buyers expense.
More info on here
http://run-it-hard.com/2012/09/reducing-the-roll/
Cheers,
Adam.
https://www.sau.com.au/forums/topic/421211-nsw-whiteline-sway-bars/
  On 07/03/2013 at 11:18 AM, whitenight27 said:
would be intro but u can get them new for 265 and 299 with free shipping
And?
$400 for the front and rear vs $564
Thanks for giving me the new price, I was unaware on what I paid for them when I bought them new....
I'm not here to rip anyone off, I've sold PLENTY of parts on here and various forums for many years, generally with good pricing.
As ususal I am open to offers.
Hi Adam, interested in the sway bars,tried to send you a PM but it wouldn't. Could you PM me so I can talk to you about them, Thanks,Regards Craig
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
