Looking the goods mate. :-)
My GTR has a spun big end (pretty sure).. so I'm in for a rebuild too.
Wish I could have the shiny goodies you got.
Ah well, beggars can't be choosers.
Good luck with the build mate, damn clean silver R you have too.
spun big end yeah that sucks .
at least yours will be cheaper then my build you can keep it 2.6L i had no choice but to upgrade .
while doing the build i thought better make it good its the only time ill ever rebuild to this extent lol
cheers for the support good luck with your build and making shit shiny :)
haha, I don't like shiny sh!t.
They look good.
But I like black.. and brushed surfaces, chrome isn't my thing.
Well - because I'm lazy I will be keeping my '26.
If I had an engine crane I'd be doing an RB30 build. HAHAHAHAHAHA.
Goodluck man, can't wait to see vids. ;-)
  • 1 month later...
so tomorrow im dropping the sump off to be welded up as it has a small crack,
also dropping the head in to be reconditioned.
getting new tomei valves and springs fitted , head shaved and acid washed.
so when i got the block back the first thing i wanted to do was paint
only question was what colour ?
kept it the factory black nice and stealth but clean .
Edited by jimbob32
waiting on the head to get done
for my nitto oil pump to turn up .
buying a garrett T04z next week and turbo smart 45 mm gate
should have the sump back in a week or so and i can re assemble and chuck it all togeather.
need to buy a good twin plate clutch and some injectors but its not long now before this motor can go back in and head to get a dump pipe made up and get tuned .
so excited now i know the car will be ready for summer iv got all the cash ready to go :)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
