Cruise to Robertson for a Pie or Pizza with the SAU NSW Clan.
Tomorrow Moaning (Sun 15.9.13)
- 9:30am @ Maccas @ E.P.I.C.
- Leave @ 10am Sharp !!!
Fill Your Tanks & BE THERE !
i dont no full details but i have been told the auto tech in hum is having a dyno day to raise money for charity -
3x runs for $75
day kicking off from 9 am
correct me if i am wrong as i have not seen anything offical just few different ppl have told me..
When this ment to be for?
How's many ppl is expected at this tomorrow? Might come as my car just came back from Autotech
How many are u thinking is gonna show? Also how fars the drive and what time will we get back.
Link to thread ---->> http://www.skylinesaustralia.com/forums/topic/430263-sau-nsw-official-half-way-robertson-meet-up-15913/
Page one has the details.
Should be at least half a dozen of us driving up and quite a few more when we get there. :D
Understood. Next cruise will be more local.
DIY Mik is gonna be fangin round the Sutton Hillclimb today.
Maybe go out and watch?
I would if not for the pie at the end. :)
ended up being around 6ish from act, and 30-40 from our end.
alot stopped at pie shop, but pizza was well worth it, so glad it wasnt as full.
  • 1 month later...
Snowy Mountains 1000 is on in 2 weeks!
Who's going? Who wants to Cruise down and watch?
I will on the Saturday but just realised that's the day I'm getting my Exhaust tweaked but I'm guessing I'd be on the way by 10-10:30am, 11am at the latest. :/
---->> http://www.skylinesaustralia.com/forums/topic/421758-2013-shannons-insurance-snowy-mountains-1000/page-1
Snowy Mountains 1000 is on this weekend!
If im not working I'll come for a cruise and check it out :)
I'll be going.
Who else is going to go and watch some mad cars going as fast as they can in a straight 1000m line? :woot:
Well if it goes the way I want it to, May take less than half an hour?
(cut off canon, weld flange *giggles* to pipe, weld flange *g* to muffler, hang it, maybe weld flange *g* to canon incase I want to change it sometimes)
Should be quicker and cheaper than making up a pipe etc like the dude suggested.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
