Righto I noticed that there is nothing like this on the forum yet..(unless I'm blind)
And I need a place to vent :D
The First thing that really pisses me off is when people drop the dumbbells. Had a guy dropping them from head height after doing some shoulder presses.. IF you can not lower the weight under control... DON'T F&UCKING pick it up!!!
People trying to do ridiculous amounts of weight on bench press where it's obvious that they wouldn't be able to move it without the help of the guy behind them.. The spotter is there to help a little bit.. Not do half the weight for you
I can think of so many more but ill give you guys a chance to express your frustration :)
  • Replies 81
Ive got heaps of complaints. Mainly stuff ive heard
"I really yeah want big arms and chest" yeah I good luck with that.
"I wish I had abs" your diet doesn't suggest that.
Then theres people who squat massive weight with a really small range of motion.
I worked with this one guy who had a massive upper body and couldn't see any reason to do leg work. He also let me know how keen he was to use roids to get big.
People that superset, but leave their shit on the equipment they are not currently using, but then go and have a drink for 5 minutes, go to their toilet, talk to their mate on the other side of the gym etc....
also people that stare at me during bench press
People nowhere near a piece of equipment, with no stuff left there either...who come and say sorry mate I was using that. No you weren't, if you were using it you'd be on it.
People who awkwardly stand near the equipment you're using, waiting for you to finish instead of asking you how long you have left. You can feel them touching you with their eyes. I tend to do an extra set when this happens.
People doing 140 pounds on lat pulldown machines who let the stack slam down at the end of their set (usually short people). It takes NO effort to use your own bodyweight to slowly release it. If I can do it with 250 pounds on the pin, you can do it too shorty.
How would you know this? You should be cocentrating on your press... Unless they re standing over you while they state of course haha
been a very long time since I went to a gym however , being told by bodybuilder types and PT's that I was going to hurt myself when I was doing heavy leg stuff - machine work (leg press/hack/ donkey) or freeweight squats .
Some safisfaction in making them feel inadequate as they watched but, usually it meant I was doing a few extra reps to rub it in and that would throw out my routine.
People who are shouting when doing isolation work like bro-cep curling.
I agree there is no pain that is unbearable when working such a small muscle
no when I sit up to rest I see them.
I don't have a spotter, have no friends
Also people who put neons on skylines, who aren't scifi fans imagining they are in a spaceship.......... thats a legitimate condition.
(in the gym or anywhere)
I also have the issue of no spotter friends, it would help to motivate me to work harder as I know I am pretty lazy.
No one would look at me doing bench press at a gym however. Your spotter would be of double value as you could have a spotter friend spot staring goofs for you and tell them where to go.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
