This morning tried pull ups again..
13
10
9
7
Welcome to the inconsistent world of pull-ups lol. Being body weight, your numbers will fluctuate with what you eat that day :thumbsup:
  • 1 month later...
Awesome thread, can't believe I didn't see it earlier!
I noticed earlier in the thread there were some chin-up numbers thrown in too, so I'll include those as well as my pull-up numbers. With my current training program, I only have 1 working set, which is further broken down in to 3 "rest pause" sets. Google Doggcrapp training for a better explanation. Cliff notes..... You do your first working set. Go to absolute failure, drop down, 10 - 15 deep breaths. Failure again, more deep breaths. Failure again, then you're done.
So.. at a height of about 175cm, and a body weight of 92kg @ around 13%bf...
Pull ups:
15
12
9
Chin ups:
22
17
13
To give a bit of insight... I was doing these same numbers at 85kg (about 2 months ago), so I'm quite happy with my strength progress. Will try 'normal' sets soon, with a bit of time in between each set, instead of my current 15 seconds or so.
Edited by Dajae
Not impossible but very unlikely...more plausible that by 200 in a row he means 200 in succession. Ala what many people I know claim similarly with push-ups, when they really mean sets...
I've seen those videos of those ripped Russian kids who do nothing but pull-ups all day and weigh <60kg, they usually top out below 100. But you do tend to find towards the end that they sit in a dead hang as a rest between reps.
He said they are proper, arm straight full length pull ups. I kept saying are you sure? He said yes. Said he trains 4 to 5 hours a day. 2 hours is boxing specific training the rest is hitt cardio and upper body training he said he does mainly cable work too.
Agreed. Possible, but very unlikely. To have numbers like that would put him into that "elite" bracket. How much does he weigh do you think? Anyone training 4 - 5 hours a day, is either blessed with amazing superb genetics, not training hard enough, or on steroids.
But hey.. tell him to make a video. That'll put a sock in our mouths eh?
Would actually love to see a video of it, not just to prove a point on the internet, but would be pretty amazing just to see it. Talk about a blood pump...
Speaking of pull-ups, in my current state I'm pulling
20
15
10
This is after being sick and taking a month off. So I've lost strength, but have also lost a few kg to balance that out...thus similar numbers to pre-sickness. It's quite a strange feeling actually, the difference in the motion compared across two different body weights.
Indeed! It would be quite the accomplishment... Especially if he actually weighs a fair bit. I mean, rock climbers that weigh <60kgs have no issue doing 30 - 50, but a big boxer doing 200? Damn.
Nice numbers man! With the pronated grip, I like going wide to hit more upper back and rhomboid action.. As a result, my elbows tend to get a little sore.
Do you get the same as this? Or are your pull ups done with only a slightly wider than shoulder width grip? If I bring my pronated grip in somewhat, I can manage a few more reps (18), but I feel it less in the upper back, and more in my forearms.
Anyone here like neutral grip pull ups? I find these to be the best of both worlds.
My pull-ups are neutral grip. I used to do wide pronated, but after (a likely unrelated) shoulder injury, I started back on pull-ups with a neutral grip for less strain on the injury. Can probably do a couple more reps this way than wide, but it does still feel like a complete motion. I feel like you can get a slight rowing benefit too, without kipping the legs up, as you can easily change the angle of your body using longitudinal hand grip (if you have the strength) and leg position to hold that angle in place. It definitely hits the abs/core hard.
Between those and deadlifts I don't feel the need to do much else, except maybe something for rear delts.
Ah ok, nice work. You're definitely right in regards to shoulder friendly benefits.. much kinder than wide pronated.
For all my pull ups/chins, I keep my legs out straight in front of me, at an angle. I find it helps keep more tightness throughout the motion, and yes, very good stimulus in the core region.
I wish I could just get away with deads and squats for "frontal core" strength.... eg abs... However my physio advised me to include some form of weighted 'crunch' movement (back friendly variety) as my lower back tends to be much stronger than the opposite muscles..
Face pulls are great for rear delts and shoulder health. Ever had much experience doing them?
In terms of that crunch movement, assuming I know what you're talking about, three recommendations for exercises I've enjoyed on the front side:
1. Captains chair leg raises, as many of these "machines" keep the lower back static with pads and, provided you have no hip issues, shouldn't give you any injuries beyond a stretched hamstring from raising too high. I usually do it after deadlifts to finish off abs, but coincidentally it's a good stretch for the hamstrings after getting them tightened on deads.
2. I have a nautilus type crunch machine that is basically a seated crunch. You can keep adding weight to it and I felt my abdominal wall develop some real thickness to it using this. Didn't take me long to max out the weight stack for 20 reps but the problem is that, like all machines, if your body isn't proportionate to it (even though it's adjustable), you can cause yourself some damage at high weights because of the rigid motion...which sounds more ironic than it is. My lower back got a bit twitchy after prolonged use of this one, though maybe I was too focused on doing more weight and lost my technique in trying to leverage it.
3. Kneeling crunches on the tricep pushdown (for lack of the proper term for this exercise), where you kneel on the ground, hold a pushdown rope behind your head and do crunches towards the ground.
I've given face pulls a go and they felt very awkward and it did mess with the joints a bit - could have been a bad angle. I must try again since my shoulder has advanced a bit. It would probably help to have someone watch and advise if I'm doing them properly, too, as all well and good to think you are doing it but it can look very different!
For the leg raises, I could never seem to feel it adequately enough in my abdominal muscles.. My hips always felt like they were doing more of the work. I tried a variation where I would hold a light dumbbell between my ankles, and with a bend at my knees, I would raise my upper legs up, and then try to "tuck up" my pelvis to my chest.. Seemed to work a little better for me.. However when a few friends tried, it had the opposite effect! Strange how everyone reacts so differently at times.
Yeah nice.. I have something similar, a weight plate loaded hammer strength crunch machine. Really like this machine.. The machines upper and lower portions are required to move, rather than just the upper/lower without the other. Definitely noticed some more "popping out" action with these!
Ahhh yes.. I love cable crunches. Such a good exercise if the form is good, ie, no swinging motion. The fact that it can be weight resisted is also a big win for me. I always believed that if you're training the rest of your body against a resistance (usually increasing weight), then the same should be done for the core. Planks with a 20kg plate resting on my glutes is also good for some isometric strength.
Face pulls can be tricky that's for sure! Found out I was doing them wrong for quite some time. Here is a video I found which helped me...
(couldn't get the linking feature thing to work :/ but if you go on youtube and search "face pull technique", the video by scott herman fitness is the one )
I'll watch you
:ninja:
Lol'd so hard. That emoticon is so good.
Edited by Dajae
  • Like 1
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
