I did not tell Leesh to continue doing exercise if it hurts, I'm the first to say stop if something feel right. When I told Leesh not to worry and to keep deadlifting, that was based on videos I saw where her form was fine - no knee hitting, just a bit of back rounding, nothing worrying, only because she was lifting heavy.
Again, she takes things a bit out of context and often neglects to mention the full story behind it.
I actually believe it is the step back to lighter weight that is causing her to squat the weight up. The heavier weight at least forced her to straighten her legs first just to get the weight up, because her back was stronger than her legs. Upping weight isn't exactly a good way to teach someone deadlift form, but I'm fairly sure her step back to lighter weight caused the issue.
I agree with rev, you are overthinking the movement Leesh. Deadlift is simultaneously the easiest and hardest movement in the gym.
- Start with the bar up against your shins
- Bend down with straight arms and grip the bar tightly
- Push you chest out and shoulders back (scapular retraction)
- Brace core / straighten lower back (this will automatically dip your hips)
- Lift and lockout
You're the one who told me to go lighter and do lots of reps and sets.
I do all those things you're saying and I'm still having problems. It upsets me when you say it's the easiest movement in the gym because it's not for me
or read?
I think Leesh you are over thinking it at the moment, which is putting you off and getting you frustrated.
Maybe take a week of deads to destress from them and then try again in another week with more of a confident/aggressive mind frame towards them.
The problem is Leesh is spending too much time lifting and not enough making sammiches....
AMIRITE?!
Badoom tish
I dont know why but I did lol at that!
Leesh - too much advise can drive you nuts so I'm reluctant to add my 2c.... but I will anyway.... most has been said and you know have to try and make sense of it all. Only thing to add is don't lift with your arms ie don't upright row the weight from the floor and then straighten up the back. it's easier to do with a light weight and maybe why you are bringing it up and hitting your knees. The arms grip the bar and you lift with the rest of the body in one movement. If everything moves together you shouldn't hit your knees, if the weight moves first, then you will hit your knees.
Hope I explained it well enough!
I have no idea what this means
thats not an instruction. its a result. The definition of close is 'relative'. If it's an inche or so away thats still close.
Mid foot is close enough. Vertical lift . Job done.
Your present issue is being 'too close'.
Edited by rev210
Dunno about you Dave, but bar above my midfoot is against my shin!
Martin Nyugen was wearing shin guards in one of the PTC vids so there's absolutely nothing wrong with having the bar travel in close proximity with your shins.
Leesh, you don't have to drag the bar up your shins so hard it hurts. Putting weight of the bar against them = bruises. It need only be close or only just touching skin as it travels up. I don't think you should be focusing on this part of the lift other than when setting up. Focus on lifting it, the proximity to your body will come automatically.
I probably didn't make the point very well. I will try to explain. The shin scrape is a 'result' not a direction to think about.
You aren't saying to yourself ' I must press the bar into my shins...'. Instead your setup and form being right causes it (just happens). I'd say most people biomechanically will touch the shin in the correct position ( I don't, setup is away and mickeys hair on the way up ) . But, whether or not it's just above or scraping along should be the result of the right motion. You mind is on other form elements.
If you are aiming to keep contact with the legs , instead of motion / form , then you might think touching the knees is part of the 'contact with the leg' and try to make contact with them. Leading to the motion going wrong at that point.
90kg x 10
130kg x 9
160kg x 5
170kg x 3
180kg x 1
90kg x 10
130kg x 10
160kg x 5
175kg x 2
180kg x 1
Have changed my form over the last week, to starting in the lifting position, rather than starting in an ATG squat position and using my momentum to get the weight off the floor.
Moved from 170 to 175. Need to bust out a third rep next time. Might move the 180 single up to 185 too.
Pretty happy.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
