Cool! Should push the bar more often (or pull it), you've probably got more in you than you think. Watch how light your old weights will feel next time!
I think you are contradicting yourself a little, you are worried about weaker muscles fatiguing before your back does yet you aren't concerned the smallest muscle which plays a big part in the dead lift letting you down
Straps and suits can add a lot of weight to te bar to help increase your overall lift
There's always forearm exercises that can be done...
During repping sets you could get maybe another two reps or even more with straps as your pure focus is on moving the bar not holding on for dear life
Nice work all round guys.
Interesting that you're the same height and weight as me yet pulling a ton more, granted I have some issues I'm dealing with but it's still a top lift in my opinion so well done.
What would you "normally" weigh if you weren't doing weights? If I'm just running and no weights I drop down to a flat 80, as low as 78 as I'm a fairly light build guy normally.
Moving to a 3x8 routine from 5x5 has been "fun" lol
That's because I'm not going to injure myself if my grip lets go, but if my core doesn't stay tight during the lift, my back will take the brunt of it or I'm robbing myself of potential during lockout..
I should mention that I haven't had any grip issues since switching to mixed grip with chalk. My back is always the first to fatigue these days; it would have to be a high rep set of a very heavy (for me) weight before my grip failed. I just think it defeats the purpose of a compound movement if you use equipment to work around a group of muscles involved in that lift; bandaiding weakness rather than addressing it properly.
  • Like 1
Markos, at what level do you think a lifter should be using a belt for deadlifts, if at all? I see countless vids on YouTube of people using belts, when they are 1RMing around the same as me or less...makes me wonder if I'm not taking a precaution I should, or if I should be continuing until I find a reason to need one...
Good question. Max deadlifted 240kg before a belt, Martin 272.5kg, Zoran 280kg.
They have now obviously added belts.
Konstantinov doesnt like them for deeds, he has pulled 426kg without one but wears one on squats.
I say try one and see if you like it
Birds/Dan, cheers for the positive comments guys.
Dan, I fluctuate between 88 and 91. If I didn't train regularly I'd be low 80's. Last time I didn't train regularly was over 15yrs ago. Prior to regular weight training I did years of paddling, surfing etc. Lots of back exercises.
The issue is being weak or bad technique or both. Piss weak grip has to get stronger. Straps won't let that happen.
Good form with deads involves keeping tension in the arms and gripping the barbell with force.
Bad technique is likely a source of so called grip issues. Any slack in the arms prior to pulling the weight and cause a loss of momentum. food for thought.
Not about being weak at all, anything around 200kg and up, unless you are superman your grip will start giving up if you are doing reps
It's about being smart knowing you could lift more, more safely focusing on technique of a good lift rather than worrying about dropping the bar or putting your back out.
Have you guys actually tried straps? I only use them on deads and shrugs and on the heavier sets but knowing how much they actually benefit a lift wouldn't consider not using them. At the end of the day most guys here I see trying to get stronger on the deads and straps will aid that 100 percent
I've been known for my forearm size by friends and gym buddies but use straps for that edge, unless you want to be a pro powerlifter I think you are mad not to use them as you can add more weight to the bar and really work the back muscles harder
Even though I can only pull 190, my grip feels like it has another 50-60kg in it at the moment. Mixed with chalk shouldn't leave anyone with grip issues. There's no one who I have taught that grip to from the start, who has grip issues. I imagine the only ones who would have grip issues with only chalk and mixed grip, are those who have depended on straps for a long time.
There's simple evidence in Markos' clients...not all of them are pro powerlifters, but I doubt he would have anyone using straps on deadlifts, and his interest is in getting people as strong as they can be. Dependency is weakness. It's a fake kind of strong IMO, if you can't do the lift without the dependency.
You guys have obviously never used them because you would know the 'edge' they give. You think chalk helps? Why do you think they are banned in powerlifting? 190kg on the bar for 5 was my pb
Hey don't get me wrong I'm not telling you what to do, all I'm doing is sharing what I know works for me and all the other guys I've trained heavy with in the past
Anything to make lifting more comfortable and get your weights up why not utilize it?
Sounds like personal preference. If you're not training for comps I say do whatever the hell you want. I wear gloves because I prefer it, you guys have mentioned it will be an issue for me, the apparent issues are not as important to me as the benefit I get, so I wear them.
I don't see straps being any different.
Action Dan they must think they are pro powerlifters with their strict rules
I was into bodybuilding not powerlifting so I used them to have hands like hooks which helps take the weight the back muscles better
Sometimes I used them on lat pull downs when doing around 300lbs
I see why they say don't use them, as the idea is to try and make the whole body strong and you're kind of working around a limitation.
But realistically, for anyone not competing it makes 2 tenths of f**k all difference so do whatever you like.
I'm guilty of this as well though, we all get caught up on specifics of things that probably don't matter that much to non competitive guys like us.
Edited by ActionDan
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
