Chalk + mixed grip = instant +50kg grip capacity.
Other than that, there are grip strengthening exercises you can do...holding the lockout on last rep for example.
I'll wade into this to rep the amateurs :)
After starting a few months ago at around 30kg with a still heavily fuxored ankle (which still is very average) and then doing a session with Matt Mat Middleton who showed me how to do it properly/better, I'm at 98kg for reps at the moment. I'm not sure what my goal is as that's dictated to some extent my my ankle. Initially the goal was BW and now the short term goal will be to get the DL and Squat above my bench for reps (a month or two I'd say).
With Matt I pulled 8 reps at 120 so there's more there but at the moment, with a 5x5 routine 3 times a week, I take the weight increments very slowly and by the time I get to set 4-5 I've already burned up some of the little power I have. I'm not out to set any 1RMs so couldn't tell you what they actually are.
As for grip, I'm starting to find in the last 2 sets that I need to use mixed grip, I also wear gloves because girly man.
I notice grip more so on the bent row which I do straight after deads so my grip gets a good work out during that portion of the session. I do weighted chins afterwards too so again grip is tested.
Don't need to do 1RM to prove anything but they are useful for bringing volume training up and vice versa. Good plateau breaking strategy.
You get better grip without gloves!
LOL Good call, but no.
Honestly, when my grip is a serious problem, which it wont be for a while at these light weights, I'll look at what needs doing, if that' no gloves, so be it.
I'm only just on the cusp of having to alternate the grip so there's still a long way to go before I run into any real issues.
In terms of how often? Maybe, I have no idea what your regime is like. I do 5x5s 3 times a week. In terms of total time spent training the motion, not sure either.
I can say I've spent less than 3-4mths so far and of that only 5-6weeks of "proper form" after seeing Matt so I'm pretty happy with my progress so far, despite the leg and subsequent back issues I've been dealing with along the way.
Oh side bar, If it wasn't obvious, previous comment was simply baiting to get a rise out of you.
Because Birds.
I assume you know this, but wanted to clarify because forum.
Edited by ActionDan
You've been doing great, no question. You attacked my lifts, not the other way around :)
My training hasn't always been about being the strongest, something few understand or mention when they talk about how long I've been training for. If that was my number one goal and always has been, I'd have joined PTC a long time ago.
Because Birds.
Well thank you for the clarification...I get attacked often enough in these here parts, it's usually safer to assume people are doing it out of malice than a good old forum ruse! Well done to you sir.
Same, I do not have the desire, dedication, balls, etc, to be a good lifter of any sort. If I can lift something semi respectable for an amateur and look semi decent I'm happy.
NP I know around these parts the line between a laugh and actual criticism can be fairly blurred for some of the people here.
Assume that the vast majority of what I say is said in jest and you'll be on the money for the most part.
Edited by ActionDan
Likewise :)
I do well for the places I go and the people I see, and that is good enough for me. I've always been in it for the looks, and by that I mean what other people find attractive, not some warped-over-time version of my own self obsession. Anything else that comes as a byproduct is a bonus!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
