Bit of a setback in training after my holiday in Perth and two subsequent colds. Earlier this week I pulled:
90kg x 10
110kg x 10
140kg x 6
160kg x 2
90kg x 10
110kg x 10
140kg x 8
160kg x 3
170kg x 1
Great session tonight. Most reps I've ever pulled on 140 and I was happy about 160 for reps afterwards, followed by a 170 single. Need to work out where to go from here - likely switch the 140 for 150 and either try 4 reps of 160 or a 175 single. Either way, I'm inching towards that 200, which would be great to pull after all my working sets.
At a guess, I'd say the volume training of 120kg for 15 and 12 reps during the deadlift competition last Thursday helped me out here. Never hurts to mix things up.
Taught my mother deadlifts last Thursday. Says to me today that for the first time in years she hasn't had back pain. Don't see how things can act that quickly, but I digress...the healing powers of deadlifts!
90kg x 10
110kg x 10
140kg x 8
160kg x 3
170kg x 1
90kg x 10
120kg x 10
150kg x 5
170kg x 1
Argh! Back so sore from about 10 sets of squats yesterday. Felt it straight away on the warmup, but I persisted nonetheless. Form probably suffered for it...oh well!
So I have spaced out my warm up and working sets, keeping them 30kg apart. Swapped 110 for 120 and 140 for 150. Really gonna miss the 140s, but it was time to get some more weight into the working sets. Gonna stick with these weights for a little while; focus on getting the 150s up to around 7-8 reps and the 1RM up to 175. The 1RM calculators reckon I'll need 10 reps of 150kg before I pull a 200 single.
Cheers Dan! 160 is double me, but 200 will be 2.5 x me hence a major benchmark. 240 isn't even on the cards for me, but it would be incredible to be able to say you can deadlift 3 times your own bodyweight!!!
Are you doing any 1RM training?
90kg x 10
120kg x 10
150kg x 5
170kg x 1
90kg x 10
120kg x 10
150kg x 5
175kg x 1
Weirdest thing tonight: 90kg and 120kg felt heavier than they normally do...must be mental. Anyway, I got out a 175kg single, which I was happy about. Would be happy to repeat that next session, with an increase in the 150kg reps...maybe 6 or 7...before I go for a 180kg 1RM.
90kg x 10
120kg x 10
150kg x 5
175kg x 1
90kg x 10
120kg x 10
150kg x 5
180kg x 1
Kind of went against my word and pulled 180...fark it was a struggle, though. Back to the strongest I've been on this lift! Come at me 200!
90kg x 10
120kg x 10
150kg x 5
180kg x 1
90 x 10
120 x 10
150 x 5
180 x 1
Not much difference in this one. Only wanted a repeat of 180; would rather get that weight be consistent and in good form before stepping up again. Tried chalkless grip on 150...bloody killed my calluses and it started slipping on the 5th rep, so I stopped. Need to try and get 6 or 7 of them next time, maybe with chalk.
90 x 10
120 x 10
150 x 5
180 x 1
90kg x 10
120kg x 10
150kg x 5
185kg x 1
Well I was going to push out 6 of 150kg...I had
It in me...but I though f**k it, if I'm feeling this good I'll save the energy for my single and attempt 185kg. Hooray! 15kg off the dream. Mate doesn't reckon I was, but I'm worried whether I'm hitching or not, so I may have to film myself and check my form. I think I'm just paranoid, cause I can't as such feel the bar on my leg...it just seems to pause for a bit as I try to lock out the weight.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
