Well title says it all but the reason for me wanting an AWD system in my car is my drive way is 1k of dirt. As you would guess my car likes to slide around a bit when it is wet even with traction control/snow on. The dream is to slap a RB26 in my Skyline one day but as my car handels great stock I was also wondering how much better the AWD system would be.
I am in no rush to do anything to my car but I just had to ask your thoughts.
Yea I thought of that but idk I am attached to my car. Selling is an option for sure but when I think of it I cry inside a little lol. I have Been thinking of getting a gt4 but if I am going to buy I may as well just get a GTR. I'm leaning to the R33 GTR but a R32 could be nice.
As much as I hate to say it, EVO or WRX make 10x the sense of an AWD Skyline for what you're wanting.
haha fair enough i dont need a full on 4X4 to get out of the drive way... well i do but the wife has a Hilux so no big deal. my car handels the mud just fine(as long as we get below 10mm of rain) i was just thinking if 2 more spining wheels would be a bit better thats all. like i said the dream is full GTR guts in my car but it may jus stay a dream but its still nice to have one.
yea ZoomZoom i live on a 226acr farm and the driveway has one hill that cant be a bit hairy at times on the way up but not to bad. if its too wet for my car to get out then the wife will just have to take me where i need to go... she has ben at me to sell the car for about a year now cuz of the drive way.
I would but i wouldent want to sell it really this is my dream car maybe not the sedan but still i am happy with it so happy i dont really think i need a turbo in it.
WRX wouldent be a bad idea :domokun: but i will stick with Skyline
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
