The first buy was a success and there still seems to be heaps of interest, so its time for a 2nd buy.
Again, need a minimum of 15 people (shouldnt be a problem) and then we can go ahead. After the order was placed last time delivery took ~ 2 weeks. Payment to be made asap via bank deposit or money order.
Please email me ([email protected]) or pm me if your interested.
Cheers,
Dave
Prices:
Clear Indicators:
Side - S15 / R33 / R34 - $70
Front - R34 - $145
Carbon Garnishes:
Pillar - R33 / R34 - $140
Wing - R33 - $110
Blank Key:
All Nissans - $65
Gear Knobs:
Leather - $70
Aluminium / Carbon - $110
Chromed Aluminium - $105
Black Anodized Aluminium - $105
Titanium - $215
Racing Black / White Plastic - $70
GT Sports Black Plastic - $85
Caps:
Oil - $115
Radiator - $55
Fuel - $80
https://www.sau.com.au/forums/topic/42134-nismo-group-buy-2/
  • Replies 83
Lucien, the titanium shifter is the one that looks almost the same as the chrome alloy but has gear pattern on top (2nd last pic in 1st thread)
13_DEVIL - 99% sure it replaces std..
Cheers Dave. Does it come with a 5-gear pattern too for R32/R33 GT-Rs?
LW.
https://www.sau.com.au/forums/topic/42134-nismo-group-buy-2/#findComment-862857
Hey dAVE,
just curious if there was any chance of getting the front indicators for the 33 M spec front bar.
I will also take part in this buy for the caps and possibly the side indicators (R33). PM me when ur ready as i am a definate.
Mark
https://www.sau.com.au/forums/topic/42134-nismo-group-buy-2/#findComment-863058
LW.
Dave: Sorry, one last question: can you get the "Nismo GT Titanium Shift Knob" (looks like this: http://www.japanparts.com/Pic/pic122/004-009.htm)?
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/42134-nismo-group-buy-2/#findComment-863498
guys, cos of the interest the group buy will close on 11/06 so need all money before then!! please pm or email me for more info.
lwells - yep, it comes with 5 speed shift pattern
slyr33 - nismo dont make r33 front indicators
gatty - that gear knob is the black alloy
strutto - yep can do, but more expensive ($285)
ahh32 - pm replied :)
guilty - blank key is just a blank key... can get one to suit most nissans and your local key man should be able to cut it.
https://www.sau.com.au/forums/topic/42134-nismo-group-buy-2/#findComment-864196
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
