Hi guys! just about too finish my rb25de conversion on my 32, and i'm quite keen to run ITB'S on it and i don't really know whats needed to go ahead just wanted too see who has done it and
-What parts are needed
-How much roughly its going to cost
-If its actually worth the time effort money
I know people say N/A's are a waste of time ect But i do have a track car thats fully built and i'v seen some n/a weapons that are, plus its my daily!!
Thanks heaps!!
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/
Ok back in a state of not so much intoxication, there is actully a few threads with guys that have done RBs with itb set ups one being I belive greg maybe with a 26/30 set up with itbs and the other an rb20 race 32.
Can it be done, yer sure. You need a custom inlet manifold to mount them to and obviously 6 itbs, a decent aftermarket ecu and general fabrication skills help if your doing it yourself as alot of the stuff will need to be made custom for your car.
Also going to rephrase what I said in the earlier post (also as Simon has pointed out), NA performance isn't a waste of time, so good results are achievable but on RB motors making any kind of mind boggling power is practically unattainable no matter how much cash you throw at them, for example gregs only made ~170rwkw, which is all well and good until you consider the fact that the motor and all the fab work has cost a small fortune and your still going to get chopped left right and centre.
Can it be done, hell yer it can... Is it worth it, I don't believe so, it does look/sound cool though and it's something different :)
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/#findComment-6778268
Do it for a point of difference on a roadcar yes, but don't expect any instant gains from it.
The build aspect is fairly easy if you have access to a CNC machinist that can make the adapter plate and weld to what's left of your intake manifold. The secret here is what intake runner length you end up with as to how it perfoms and this varies on what other mods you have.
I built my ITB engine for a specific class of rallying. I wanted to skid an R32 and have the reliability of an RB to run in a 1600 - 2000cc capacity class. (note a turbo would put a 1.8 multiplyer on my cc rating) It took a few years of tuning and tweaking, but four or five years on it is making easily over 100hp/litre, has great throttle response and is very competitive.
I wouldn't be so keen to have my setup in a roadcar (especially a daily driver) as it just isn't that drivable in traffic. Most of that would be down to the cams I run and the fact it is tuned to function in the 5,000 - 9,000rpm region. 1,500 - 3,000rpm just isn't any fun surging along.
If you outsource the work, yes it will cost you a bunch of cash.
It will never make hp/litre like a Honda.
It will sound cool.
PM me if you are interested in details of the setup I run.
  • Like 1
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/#findComment-6783039
  • 4 months later...
Digging this topic back up, a guy i know has an itb kit made to suit an rb25 which he says should just bolt on. Does anyone know what else would be needed to get these running on an rb25de series 1( the previous owner said it was a series one rb25de but i'm pretty sure it has vct:S)?
id be planning to run these with a nistune ecu and a set of 264 degreee cams, would you really see a worthy gain? i would be running these with an rb26 plenum not the velocity stacks.
http://www.ebay.com.au/itm/Nissan-Skyline-RB25-RB26-ITB-Adapter-Kit-Complete-kit-ready-to-bolt-on-/281127320647?pt=AU_Car_Parts_Accessories&hash=item41747e7c47&_uhb=1
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/#findComment-6931683
In a nutshell:
Cool Sound from intake
Still a terrible sound from exhaust
Slow
Torqueless
Boring to drive compared to a turbo car even though it has mad ITB sound
Money spent will make you depressed a month after driving it realising you built a slow car that makes a throaty intake noise lol
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/#findComment-6932187
its had a series one r33 RB25DE swapped into it at some point in time. yea i know turbo is the way to go if you have the choice, but am on a P plates at the moment, so not really an option. Definitely on the cards once i get my full licence.
Had a bit more of a look into it and i don't think it will really be worth the effort, going from an rb25 plenum to an rb26 plenum is going to kill the low end response due to the short inlet runners, plus will have to change the TPS sensor and a bunch of other stuff. Think ill just leave it to cams and a nistune and leave it like that till i get my full licence.
https://www.sau.com.au/forums/topic/421359-rb25de-itbs/#findComment-6936293
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
