Hey guys,
I finally found myself a non-molested R34 GT-T Completely Stock with some nice 18" Enkei wheels
Here she is fresh from Japan. with only 59,000km on the clock
I look forward to going through the forums & getting involved in some cruises.
Edited by Sammit
https://www.sau.com.au/forums/topic/421380-hi/
    • My OCD says that exhaust is sticking way to far out for a BMW.   Sorry for making you now upset with your exhaust again...
    • That is not true. The R32 GTR wiring diagram is freely available and has been for literally 25 years. And you don't even actually need it because the situation is so simple that you literally only have to use the wire that runs to the original dash indicator. Your car has a problem. That problem is unique to your car. I assure you that if I went out and did it to my car right now, it would work.
    • Thanks man, yes unfortunately normal bar went on after a minor accident. Smash repairer ordered the wrong version, needed my daily driver back asap so just accepted it.  Hoping an aero bar in gun metal grey (KH2?) pops up for sale soon, I know paint from different cars won't match perfectly but will look good enough
    • If it is the case that your stock dash high beam light lights up as it should, all you have to do is tap into the power wire for the high beams dash globe and feed it to pin 25 on the Haltech dash.
    • I thought you said the stock dash high beams light doesn't light up when you push the stalk forwards and lock the high beams on?
