oh, so a random Guy with a low power setup claims such massive differences with no dyno proof, and that means somehow I am losing heaps off power to a non existant coil issue?
cool -__-
cool -__-
Whoa guy - why so defensive? If you haven't tried the coilpacks back to back yourself, why are you so strongly convinced there is no difference?
Sorry that came across a bit harsh. Fair point, but when a combo makes the expected power, and comparable to others, I dont believe im losing out on any power. The people that pick up power are doing so because their old coils werent working properly. Actually losing lower by changing coils (unless the new coils are faulty) hasnt been proven. There are back to back tests that show there is no power to be had by replacing functioning coils with another brand.
im not willing to do my own back to back test, but I will have a set of yellow jackets available soon, as I am going to use ls1 coils I got for nothing. If anyone wants them, they can have them so long as they do a back to back test when installing them.
Ben
Thought I'd save some coin by buying the JJR (red) coil packs...
15 months later = FAIL (stock turbo@10psi)
BTW - My tuner said that the popping/misfiring under boost caused by these POS coil packs could be as damaging to the engine as knock!
Replaced with Splitfires...
15 months later = SWEET (3076@19psi) never missed a beat
Not only did I not save money by going cheap... it actually cost me and extra $400!
Edited by Checkbuzz
dude, heaps of people make twice your power with yellow jackets. I am making 274rwkw with them. explain how that can happen if they are so shit?
he didn't say these coils won't make power, he said on HIS setup he made less power with the yellow coils then he did with the stock ones and how do you know 1) he didn't make less power, and 2) your setup won't make more power by putting stock coils on your car, you've said our not will to try it but are willing to take a shot at someone that has
cool -__-
why so angry, he is just telling us what he has experienced with his car, what does his power setup have anything it do with this issue if anything the fact his setup is so low power showing that kind of difference would mean it would be worse on a mild setup like yours and even more so on bigger setups
can you prove he didn't and if your not willing to test them how do you know you don't have an existing coil issue or won't make more power by changing them and if you don't have an issue and these coils can make the power why are you changing them ? cause, and please correct me if I'm wrong, free or not the LS1 coils are not a plug and play setup and remove the factory look giving a greater chance of a defect if pulled over
i made 360 rwkw on a neo rb25 with yellowjackets and plugs gapped at 0.8mm running e85.
have heard of others not having such luck with them. same goes for splitfires.. success stories and dramas everywhere.
my motor now runs MSD blaster coils... the spark these babies throw off is nothing short of frightening
Thing in China is. If one business makes money by copying some thing (doesn't mean it works), then every one else follows. They will also try to produce and sell them at a cheaper price. Externally they appears identical, internally they could be very different.
I think you missed his point, he made less power on his setup with them so if you change the yellow jackets to stock and you might pick up x amount of power on your setup
Exactly the point, and to make sure the testing was fair i ran them all on a stock car with minimal mods(not even my car) I did the tests quite a few years ago simply because i was curious to see just how much difference there was from coil to coil, the only new set of coils involved in the tests were's the yellow jackets, the stockers and splitfires were old ones of previous setups of mine and had done easily 20,000km's on the split fires and the stockers around 80,000km's
cool -__-
Yes thats exactly it dickhead. why dont you go and pay for dyno time to test some coils and see what results come from it and tell me how much you feel like sharing your results for others to gain from?
I performed the tests over 3 years ago stock car as i thought it was the only fair way to test back to back. I hope the shitty yellow things have improved A LOT since i tested them but i cringe when ever i see them on a car. The sad part of all with the test i performed is that the car idled nicer and felt smoother with those shitty yellow things on it but once the tests had been done both myself and the owner of the car where extremely suprised and shocked.
Spark is not something you should cheap out on but if you are on a tight budget look into retro fitting LS series coils which can be had extremely cheap from the states. If you want the best there is out there.. BPP's CDI setup is the most impressive bolt on solution but comes at a cost and its not a complete bolt on plug and play.. you do need to snip and crim the 7 ignition wires into a new plug(supplied) to suit the new ignition harness.
No need for name calling...
So we could assume the coils have improved, as there are plenty of people making 250+ with yellow jackets.
At the end of the day,i don't care. the coils were on the car when I bought it, and I will be going to ls coils as they are clearly heaps better. But I seriously doubt I would make more power as there is no issue currently.
you would be surprised how much they pick up with a larger gap and decent coils....
If my mate (Sloane) goes for the splitfires and gets rid of his yellow jackets, I'll ask him to put the car on the same dyno and see if it will run more than it's current 370.8RWKW.
Interestingly I definitely felt improved power output going to the yellow-jackets over the stock coils even though I had no issues with the stock coils. But then again I also indexed the new plugs I put in by facing them toward the intake ports.
dont know.. as no other coils would work haha.
best part was the MSD blasters are 70 each (need 3, run wasted) plus a set of custom leads and an ignitor. strongest spark ever
Ergh if they are so cheap why did I blow ~$500 on yellowjackets If I could get these MSD blasters for that price?
Any info/links?
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
