R33 Series 1 And 2 Stock Parts. Make An Offer. Going Cheap!
I have the below parts for sale. Make an offer. Stripped a few cars and got many little parts left over.
got other boxes full of shit i havent looked through yet. Sing out if there is something u want i dont have listed. Very keen to get my garage back.
make an offer. will deal for several bits. have pics of most parts but not wasting everybodys space with them. just ask.
Purple passenger mirror 25
purple door driver 50
purple rear bumper bar 40
airconditioner condenser 70
random aircon hoses ask
power steering rack
70 hicas rack 70
speedo cluster 192km 50
radiator shroud 40
washer bottle 20
rubber gearbox gearstick cover 15
shifter surround 30
kick pannell 20
s1 rear trims 30
gearbox flex plate 30
NA brake callipers think rear 70
jack 30
bonnet latch 30
aircon compressor 70
charcole canister 15
silver driver side tail light 35
low + high pressure power steering lines 40
clitch master + clutch line 60
clutch master 40
coilpack loom 35
horns 20
aeriel with cable 40
some skyline mats not full set 30
bonnet cable 30
under steering wheel colum cover 20
clear skyline rear tail light garnish 30
random nissan clutch slave. Unsure what it fits. Maybe sr? 30
rb25 gearbox shifter with gear knob 40
r33 centre dash vent undamaged 40
space saver x 2 30 radius arm rods 40
right hand side front lca control arm 40
r33 half shafts left and right 60
injector loom 30
s2 abs pump motor 50
s1 wiper indicator stalk 30
s2 wiper indicator stalk 40
s2 passanger airbag 40
centre radiator / bonnet catch support 40
radiator overflow tank 30
driver side a pillar 25
brake and clutch peddle 40
r33 metal window seal. Bolts to car above door 30
sunroof motor 30
light with sunroof control 25
interior light 20
hand brake cable
20 several clock springs 30
glovebox 30
airbag computer 30
climate control units 30
brown windscreen wiper relay box 30
illuminted ring for round ignition barrel 20
amber side indicators with silver surround 20
aircon reciever dryer 35
battery hold down clamp 20
top radiator holders 20
single din sized pocked for under radio 20
heaps of seatbelts 25
several starter motors 35
tyre iron 20
windscreen wiper motor 30
ecu bracket 20
  • 1 month later...
Hi I'm chasing up a air bag steering wheel for a 95 skyline, just wondering I'd you have one. If so call or txt me 0417438691
Edited by Chopper888
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
