Ok so I bought some Defi gauges. 60mm white Oil Temp, Oil Pressure, Water Temp, Tacho with the control unit. Don't really want the tacho but the guy wouldn't seperate lol, so if anyone is after one I'll be selling one soon.
I plan on mounting them in the stock gauge position so if anyone has pics of theirs installed that would be great. I've been told a bit of creativity with the brackets is needed.
ive been wanting to do the same thing but wasn't been able to find a right up/how to for swapping the gauges. if you do end up doing it could you please show how you did yours. that would be great thanks :)
though beautiful car though mate been following your build for a while now :)
  • 4 weeks later...
Small update, still haven't fitted the Defi's, soon hopefully haha. My plan is to fit an oil cooler at the same time so I think I will do it at next service as to not waste the oil in the car.
I went to my local exhaust shop and got him to make up a new straight through pipe to take out the mid muffler in my exhaust, it isn't all that much louder, bit more crackly which is nice. I have kept the old section though so if it ever becomes an issue I can just switch it back on :) . The guy also fixed up a bracket on my dump pipe too as there was a lot of movement in the exhaust as the first bracket was down near the diff.
Bought a pair of Rota P45R2's in 18x9.5 +20, due to having buckled one of my rims back at Wakefield, they should be here soon I would hope. I will buy another pair when I have more money lol. I know everyone isn't a fan of Rota, but with wanting to drift my car I don't want to spend lots of money on wheels only to ruin them at the track.
Will be attending some hill climb events at Mount Panorama on the 1st/2nd March, pretty keen for this. Plan is to hopefully do clutch/flywheel after this but before the motorkhana at Easter, will have to see about funds though :(
Also, my housemates girlfriend is into photography and wanted to try out some HDR style shots using my car so I got a friend with a R33 to come along too and below is a couple of pictures she did :)
  • Like 1
pretty sweet editing with the photos they do look great kudos to your housemates gf for excellent shots
as for rotas well..not everyone has a bank account that can afford volks or work etc etc.. plus theres no point (in my own opinion) spending that sort of premium for a not so aggressive gtt fitment haha :) im looking at getting a set or rotas theyl be just cruising wheels and my stockers will get the abuse.
awesome as always mate :D
Cars looking good Tim
What colour did you end up getting them? I went hyper black with mine :)
Got a pic? I'm going to get my rims resprayed gloss black but curious to see what hyper black looks like
  • Like 1
looking good mate.. are they matte black? some ones been fingering your wheels holes will all them smudges on them already :whistling:
what tyre sizes did you run with bro?
I'll put a pic up as soon as they arrive (if tim allows a small thread hijack :D) either tomorrow or early next week I'm told (exciting times)
Send me a PM instead, that way we don't mess up Tim's thread :P
Yea will post pics this arvo when I fit the new ones too.
They will fit no probs, if you've lowered the car a bit you will need to roll the guards but not flare, as long as your camber isn't anymore positive than -1 :P
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
