Fitted the wheels to the front today, pretty happy with the appearance, definitely keen to get another pair now though lol.
I realised just now that I only took one photo after putting them on though haha. I'll post some more later :)
I've also realised that I have much more room to lower the front now that there are 225's on the front!! :D
  • Like 1
Just got home from Bathurst from competing in the first two rounds of the NSW State Hill Climb Championship. Day 1 was backwards up the Esses, unfortunately it was raining all day which slowed the times a bit, meant I had a bit of fun though ;) . Day 2 was from Mountain Straight up to McPhilamy Park, luckily it stopped raining that night and after the girst group of cars the track had dried up :) . I managed to pull off a third place for my class both days, even though my car was still setup exactly how I drifted it (nice and stiff) and running stretched Rotalla tyres on the rear of the car haha. YAY two trophies for me haha. I will post up more pics and vids tomorrow :)
  • Like 1
I have to admit I was surprised seeing as it was a state level comp. I think I only managed it because I was (the tiniest bit) less scared of hitting a wall haha. Couple of videos uploading now so will post in the morning and will get some more uploaded during the day hopefully :)
  • Like 1
Here is an inside view of my fastest run up the Esses. As you can see it is quite wet so there is definitely room for improvement :P
This is an outside view of my smoothest run up top of round 1
Edited by timmy_89
  • Like 2
One last video. View from the outside GoPro on my last run.
The clutch smelt very bad at the end of the first day after missing third gear and then kicking the shit out of it trying to get the car sliding up the top haha. It started to smell again at the end of the second day, so I am definitely in the market for a new clutch before the next event. I've got a quote from NPC and have tried calling Jim Berry but have had to leave a message. Once I hear back from him I will make a decision on which of the two I will go with and then buy it and hopefully get it all fitted before the motorkhana at Easter :) . Other than that the car performed faultlessly all weekend which is great :D
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
