Finally got some spare time and started looking at my Defi's and trial fitting them.
I am going to attempt to leave the cups on them and get a thin bit of steel rod to put through the mounts to help with aligning them together easier, I'll post pics and let you know how it goes.
My first lot of deliveries for the week turned up.
Gearbox oil (Redline Lightweight Shockproof), all new seal kit, clutch alignment tool (which as I mentioned turns out I'll be getting with the clutch anyway haha :( ) and also a magnetic sump plug which I will chuck in next time I drop the engine oil.
Edited by timmy_89
So, I finally got around to fitting the Defi's this week. I'm still to fit the sensors, but the gauges themselves are in lol.
I tapped into the IGN power, ground and illumination from the cigarette lighter and then the constant power leading to the head unit for the control unit, thinking I will velcro it into the glove box but currently it is sitting in the passenger footwell lol.
I love how easy it is to pull shit apart in R34's lol.
Someone asked earlier to post pics on how I mounted these, so here it is, I siliconed them! Haha, looks a bit sketchy but I didn't want them falling back and silicon is easy enough to get off so I figured more was best lol.
Fitted up. Not 100% perfect alignment but you can't really tell.
With headlights on.
Edited by timmy_89
No boost gauge?
Nar, I have the e-boost to check if I need to (currently sitting in the glove box).
If I get another gauge I'll probably pillar mount it and whatever the other one is (only other one I can think I'd get would be AFR but that won't be until I do a bit more engine work).
I've still got a water temp gauge I want to hook up and have looked at AFR as well but as much as I want them in the car I dont want to go through the hassle of pillar mounting them only to get defected
Don't you have an AFR? :3
I don't see it as a necessity just a precautionary thing.
Yep in the glovebox out of sight! It is simply there for troubleshooting if anything goes wrong.... The Haltech protects the engine so no need to watch what its doing!
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
