aw man thats horrible at lest you got off easier then it could have been, those defects are easy fix's though right? slap on some stockies. make a cold air box (i have the stock box and snorkle i can send up to you if you want) and just jack up the coils?
best of luck with it mate!
Yea definitely could have been worse, just a pain in the ass. The defect notice requires a full inspection/blueslip to be cleared though, so it depends how much of a c*nt the local guys want to be. I just went and saw one guy during my lunch break (everyone has been recommending him to me as being the more leanient of the local guys) and he said make the exhaust quieter, stock wheels, stock air box (I still have my stock one luckily, but thanks for the offer :D ), and raise the back of the car up a little bit and it should be ok. He didn't really look at the car though so I'm a little skeptical he will change his mind tomorrow which I was luckily able to book the car in to be checked on.
Well, yesterday I raised the car suspension and had it realigned. All was good in the world. Until I decided to test the newly acquired launch control with semi's on haha. Now I'm on the hunt for replacement driveshafts. Better now then at the supersprint or hill climbs I've entered next month lol.
Anyway, for your personal entertainments, here is a video of bangs and flames.
Edited by timmy_89
Well I managed to source some second hand drive shafts from a fellow SAU member nice and cheap, and then it turned out I had a friend who would be driving within about 5kms of where the guy lived, so he picked them up for me the following day, which meant I had my replacement driveshafts before the weekend.
The process of changing the driveshaft over was actually easier then I thought it would be. Just unbolt the upper arms from the hub and the 5 bolts on the diff end and with a bit of maneuvering I was able to slide it out.
After bolting everything back up it was time to have a couple of beers and open up the boot on the old shaft. Whilst removing the from the car, it felt pretty obvious that the CV was shattered.
I figure it can be repaired with a bit of superglue right?
  • Like 2
Nice build mate. How much did the gear box shipping cost? I had a look at RHDJapan website and the box itself is around 1.6k aussie. Did they charge you much for shipping?
Cheers
Amir
Cheers.
At the time it cost me ~$1800 for the gearbox and ~$400 for shipping.
  • 1 month later...
So yesterday I entered myself into the supersprint at Mount Panorama held by the Bathurst Light Car Club, the first supersprint that had been ok'd by council in the last 3 years.
The day started out beautiful, but made a drastic change into a downpour of rain after only the first couple of runs which meant I really only got 1 sighting run and 1 "fast" lap of 52.47 seconds before the track was wet.
In the end they had to call the day short (still managed a few wet runs). Definitely something I'll be aiming to get to again to improve on times.
Vid of my last run in the wet, which as you can see was slippery as hell!!
EDIT: Second YouTube link not working so posting in next comment :)
Edited by timmy_89
  • Like 1
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
